Interior/Exterior Dash Cover Rattle
Old Dec 28, 2005 | 06:34 AM
LakeHelen's Avatar
LakeHelen
Dash Cover Rattle
Last time I was at the dealer I asked them to fix a rattle in the dash. Some time after that I noticed a lump of black sticky glue at the junction of the windshield and the dash cover, right in plain view. It took me awhile to figure out this was the rattle fix the dealer had perfromed. Last weekend I removed the black lump of glue with and the rattle is back.
I want to try to fix the rattle without a visable black goo gob on the dash. Can I insert a foam weather strip under the dash cover? Does the dash cover come off without much trouble? Any help is appreciated.
Old Dec 28, 2005 | 12:21 PM
JCW Driver's Avatar
JCW Driver
The dash rattle repair method they use at the local MINI dealer here, requires the use of a series of felt pads placed underneath the dash, that alleviate the rattling.
I've never heard of the black goo method. That sounds kind of suspect.
Old Dec 28, 2005 | 01:12 PM
Darin45's Avatar
Darin45
yeah my rattles to and its anoying. I know it comes from the dash but I'm not sure where. I havent had time to head over to the dealer but wondering if anyone else can chime in on this matter...
darin
Old Dec 28, 2005 | 05:34 PM
LordOfTheFlies's Avatar
LordOfTheFlies
It's *really* easy to remove the top of the dash and investigate yourself.
There are two torx 25 screws on either side of the dash that you need to remove under the panels (pull rubber stripping and gently pry panels out) and two torx 25 screws right near the dash illumination control and hazard lights.
You can use some self-adhesive felt tape and cover up suspect spots.
Really easy......
Shoe
Old Jan 6, 2006 | 08:18 AM
LakeHelen's Avatar
LakeHelen
Fixed Dash Rattle
I used a foam gap filler product. Looks like a foam dowel rod 5/8"diameter, used to fill large gaps prior to using chaulk. Cut a piece to fix entire lenght of dash. Pressed in with a wooden kitchen spatula in the space between the windshield and the dash. The color is light gray and it went in without any trouble. No rattles so far.
sevin
May 2, 2026 06:11 AM
woodstudio
Mar 15, 2020 08:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
iclancy82
Aug 11, 2015 09:35 AM
