homelink system
Old Dec 25, 2005 | 04:36 PM
MiniKJ's Avatar
MiniKJ
homelink system
Happy Holidays to all:
Hope you had a nice Christmas dinner. I was programming the homelink system this morning with no luck. I followed the exact procedure in the manual, but the system didn't seem to pick up the code from my remote (rolling code garage opener). So I went on to try pressing the trained button 3 times after pressing the learn button on back of the garage motor unit. No luck, I erased all codes several times and re-trained the button several times, same deal. I even followed the garage door MFR instruction to train the homelink system, still going no where. Could anyone please kind enough to offer some help?
Old Dec 25, 2005 | 05:38 PM
MiniKJ's Avatar
MiniKJ
Sorry guys, I went to the homelink system site and got better instruction. I got it figured out. Thanks anyway.
Old Dec 25, 2005 | 07:22 PM
Tarzan's Avatar
Tarzan
You're really gonna love that homelink feature. It took me lots of trying to get it programmed as well. I had to do it in a certain order to get the car programmed without erasing my outdoor keypad or vice versa. The Homelink website was the key.
Old Dec 25, 2005 | 07:43 PM
schernov's Avatar
schernov
Is there a way to fit into a 2004 mini?
Old Dec 25, 2005 | 08:40 PM
MiniKJ's Avatar
MiniKJ
It turned out to be a dying battery in the remote. It took 3 seconds for the homelink to get trained once a new battery was used. It took me less than 2 minutes to program the second garage with my wife's help. I am loving it.
Old Dec 27, 2005 | 07:22 AM
drdave's Avatar
drdave
I posed this same question a few months ago. According to my service advisor this can't be retrofitted to earlier models. I have asked that anyone with this mirror to please remove it (it is very easy to do) and tell us how it is wired. We could then try to wire for it ourselves.
I'd love to be able to add the Homelink mirror to my 2004 since I have 2 garages.
Old Dec 27, 2005 | 09:58 AM
schernov's Avatar
schernov
So homelink is in in the mirror, right?
How about getting a homelink unit from BMW 3/5 series and put it into the black oval plastic cover where the sunroof switch is in...?
Old Dec 27, 2005 | 10:43 AM
drdave's Avatar
drdave
I've already tried that with no success but it was with a different OEM brand of transmitter. I did buy a BMW unit but it was for my wife's 323 and it is prewired for it.
Old Dec 29, 2005 | 08:22 AM
schernov's Avatar
schernov
Homelink only needs positive constant and positive switched (depending if you want it to work all the time or only with key in)...any generic homelink transmitter should work.
How about just replacing the whole mirror with aftermarket one with homelink>
Old Dec 29, 2005 | 08:48 AM
kenchan's Avatar
kenchan
you might want to use a battery for homelink (not the car battery)...because
each time you unplug your car battery it'd be a pita to re-program it again.
Old Dec 29, 2005 | 05:22 PM
Tarzan's Avatar
Tarzan
The homelink rearview mirror retains its programming when you disconnect the car battery--just as your garage door opener continues to work after removing and reinserting its battery.
Old Dec 29, 2005 | 07:19 PM
kenchan's Avatar
kenchan
you know wat, you're right.
my head was somewhere else.
Old Dec 30, 2005 | 04:40 AM
drdave's Avatar
drdave
I'm aware of that but I would still like to see what the wiring harness/plug looks like for the Homelink mirror. While I was digging around inside my headliner looking for a 12v source I came across a couple of unused plugs above the sunroof switch.
I don't think that an aftermarket mirror would fit the MINI mounting point.
bahman
Nov 15, 2019 05:45 AM
Filmy
Sep 7, 2015 08:27 PM
Filmy
Sep 7, 2015 11:27 AM
Sep 4, 2015 02:34 PM
M7Speed
Sep 4, 2015 10:47 AM
