Suspension Remove nuts JCW stray brace
Old Dec 22, 2005 | 05:02 PM
Maaij's Avatar
Maaij
Hi
Tomorrow I need to remove the JCW strut brace because I have to fit new shocks. The JCW strut brace is tighten to the body with locking nuts (they have a blue plastic lock sleeve on them).
I read I cant use the nuts again if I loosing it? Is this true?
Can I still use the nut if I add something like loctite?
Old Dec 22, 2005 | 05:11 PM
newbs49's Avatar
newbs49
Check for a thread about bad nuts that crack and fracture. I would suggest new if you can get them.
Old Dec 22, 2005 | 05:16 PM
newbs49's Avatar
newbs49
Check
JCW Strut brace=poor quality
Old Dec 22, 2005 | 05:25 PM
rcoopers's Avatar
rcoopers
according to JOHN COOPER WORKS the part number for the nuts is:51717895241_____i received this number from john cooper, parts manager for JCW i had asked him for info because of some problems the folks on mini2 have reported.he said they have not received any complaints about the nuts splitting apart and he would keep me supplied with any info.....
Old Dec 22, 2005 | 05:33 PM
newbs49's Avatar
newbs49
Maaij
Have you checked with the dealer you got the bar from? He may have a few in stock and may be nice enough to take the nuts out of a kit. Worth a phone call.
Old Dec 22, 2005 | 05:37 PM
chows4us's Avatar
chows4us
TWO (2) people report failed nuts and the sky is falling
Too funny
Old Dec 22, 2005 | 05:54 PM
Maaij's Avatar
Maaij
Thanx for the replys
I dont think my dealer have it in stock. Can I use the old one till my new nuts arrive?
Old Dec 22, 2005 | 05:59 PM
chows4us's Avatar
chows4us
What did MINI say? Your dealer would know.
Old Dec 22, 2005 | 06:20 PM
kenchan's Avatar
kenchan
why don't you just go to Acehardware and get some metric nuts with
locking nylon? who cares what the nuts look like under the hood.
Old Dec 22, 2005 | 06:23 PM
not-so-rednwhitecooper
i dont think they are a standard bolt, from the pictures i have seen.
Old Dec 22, 2005 | 06:48 PM
kenchan's Avatar
kenchan
oh? what pitch does it use?
Old Dec 22, 2005 | 07:41 PM
rcoopers's Avatar
rcoopers
thestrange thing about them is they have a sleeve on them that is nit threaded it self taps itself as you wrench them on.anyway that was the way mine and another that i did were.i have e-mailed JCW and asked them if that is correct and i havenot received an reply from them yet. i'm not sure if that iscorrect butthat was the way they went on. the instructions are very clear about the install but it is a very straight forward install.....
Old Dec 23, 2005 | 01:54 AM
Maaij's Avatar
Maaij
Let me know what JCW say about it
Whats the torque setting of the nuts? The brace itself is 34Nm?
Old Dec 23, 2005 | 04:06 AM
holdenontoit's Avatar
holdenontoit
these are called "nylocks" and are available almost anywhere that sells metric hardware. They ARE a "one time use only" item and should be replaced when removed. Jock
Old Dec 23, 2005 | 04:17 AM
pooch1's Avatar
pooch1
You are correct sir.Nylocks are commonly used in industrial high vibration environments,one use only because you cut a thread in when you tighten down locking it on.If you reuse you will pull the raised material cut on the firstuse out and it will loose" the locking feature".
Old Dec 23, 2005 | 05:43 AM
kenchan's Avatar
kenchan
so now we know what to call what I already described....
what pitch does it use so the poor guy can get some locally.
Old Dec 23, 2005 | 05:48 AM
mamarazzi's Avatar
mamarazzi
Too funny
They failed on mine too.
Old Dec 23, 2005 | 05:49 AM
holdenontoit
Bring an old one and "they" should be able to match up the correct size.Otherwise you would have to have a bunch of really expensive gauges, or at the very least a metric thread pitch gauge set.
Old Dec 23, 2005 | 06:36 AM
1FSTMINI's Avatar
1FSTMINI
You wont find these anywhere but the dealer. They have a colar extension to take up the slack between the hole and the stud coming out of the mount.
Old Dec 23, 2005 | 07:21 AM
Maaij's Avatar
Maaij
Thanx again for the reply's
I called the dealer and they can order it for around $6,40 each
I need 6 pieces
Old Dec 23, 2005 | 07:32 AM
1FSTMINI's Avatar
1FSTMINI
List is $6 ea.
Old Dec 23, 2005 | 07:33 AM
chows4us's Avatar
chows4us
Sorry to hear that ... OK three (3)
Anybody else. I just dont think 3 ... or 30 ... warrant a recall or panic.
Old Dec 23, 2005 | 07:34 AM
Maaij's Avatar
Maaij
Originally Posted by 1FSTMINI
List is $6 ea.
still expensive
Old Dec 23, 2005 | 07:38 AM
Maaij's Avatar
Maaij
How many failed nuts? Do you fitted it yourself?
All failed nuts so far is coming from ppl who fitted it himself.
Old Dec 23, 2005 | 12:42 PM
newbs49's Avatar
newbs49
Maaij
I really wouldn't use nylocks over again. You could but they may come loose. Why don't you leave the bar off until new ones come in,and use the old nuts that were on the car before bar install.
W0TM8
Dec 19, 2019 07:50 AM
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
