bypass valve question.
Old Dec 18, 2005 | 07:15 PM
minimotoman's Avatar
minimotoman
Since the bypass valve has been the topic of debate, has anyone tried to block it off all together so it is sealed and does not operate. Thus not leaking, not yo yoing or any ill effects.
Or does the supercharger at idle/ low rpm not supply enough air?
Just curious......
Old Dec 22, 2005 | 08:31 AM
GoMiniGo's Avatar
GoMiniGo
The actual air path of an open BPV is to dump the post supercharged/intercooled air back into the flow path right after the throttle body. The BPV is not open to the outside world. It is all a closed path system so to speak. Make sense?
Sealing/Closing the BPV has been done with a tie-wrap by others. If I remember correctly, this eventually turns on the SES light.
GMG
Old Dec 23, 2005 | 07:11 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I did the "zip-tie" mod a little while ago, and changed the whole BPV for a Detroit Tuned one since then...
From what I've read, the zip-tie mod can turn the CEL light on, but also over-heat the supercharger...
I think a better BPV (with a stiffer return spring) and adjusted correctly is the way to go!
Detroit Tuned BPV comes already adjusted and ready to install... If I had to do it again, I wouldn't hesitate a second! Detroit Tuned kind of release power from the engine.
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Emnotek
Sep 29, 2015 07:37 AM
Nicefeet
Sep 24, 2015 06:53 PM
