Suspension Anyone with Yellow shocks? Paint it or not?
Old Dec 9, 2005 | 02:16 PM
Maaij's Avatar
Maaij
Hi
I am getting a set of Bilstein shocks. These shocks are yellow. I have a PW/B Cooper with JCW wheels. The JCW wheels are very "open" so its easy to look inside of it. I am afraid the yellow shocks doesnt look right on my car.
Can you see the yellow shocks easy if you stand next or behind the car?
Maby someone have a pic of a MINI with yellow shocks
Is it a good idea to paint the shocks black? Or is this not nessesary?
Thank you
Old Dec 9, 2005 | 05:42 PM
kenchan's Avatar
kenchan
i'd paint it if it bothers you. just use enamel paint.
Old Dec 9, 2005 | 06:07 PM
kyriian's Avatar
kyriian
this is mine with konis.. you can't even see em!
in the back is a bit more obivious... but again, the wheels pretty much block it completely, this is before the wilwoods, so its showing even less now
Old Dec 9, 2005 | 06:17 PM
Maaij's Avatar
Maaij
Ok thanx for the info. Do you (or anyone else) have a pic of the rears
Pics tells a lot more then words
Old Dec 9, 2005 | 07:12 PM
kyriian's Avatar
kyriian
here... i ran outside in the freezing cold for you!
this is straight at the wheel
this is angled a tiny bit to look for the konis specifically
and the last shot is from under the back, close to the muffler... only place i can get the konis to show
Old Dec 9, 2005 | 07:20 PM
cooldaddy's Avatar
cooldaddy
all I got to say is Bronze wheels Rock
Old Dec 9, 2005 | 07:33 PM
Yucca Patrol's Avatar
Yucca Patrol
Now that is a dedicated NAM member, willing to brave the cold just to snap a helpful photo!
Old Dec 9, 2005 | 08:36 PM
Hubert's Avatar
Hubert
Hi Maaij,
It's better to leave your dampers untouched.
It's not a good idea to add another layer of paint onto the dampers, because it might affect the damper's ability to dissipate heat, especially if you choose the wrong paint.
When you drive your car, the dampers transform kinetic energy into heat, that's why they get warm after driving for a while. As you should know, the hotter the damping fluid, the less viscous it is, hence the damping ability changes. In an ideal world, we want a constant damping fluid temperature for constant damping behaviour.
That's one of the reasons why some of the more expensive racing suspension have larger damper pistons and damper tube diameter to hold more fluid, to minimise the effect of damper fluid heat up and improve the damping stability.
Old Dec 9, 2005 | 09:19 PM
Maaij's Avatar
Maaij
Thanks for you great help kyriian The pics looks great
What tire size are those Dunlop Studless? Is it the same size as your tires on the Subzero wheels?
Originally Posted by Hubert
Hi Maaij,
Thanks for the info. I will leave it like it is now
Old Dec 10, 2005 | 03:07 AM
Hubert's Avatar
Hubert
pleasure
smdmini
Oct 7, 2019 06:05 AM
richardsperry
Jul 30, 2018 04:48 PM
vicj
Jan 16, 2016 04:36 AM
Systemlord
Sep 19, 2015 02:57 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
