Interior/Exterior Aux gauges @ steering column
Hey Guys and Gals. new 06 MCS S. I purchased seperate gauges that bolt to the side of the Tach. Factory boost gauge and Batt Charging gauge. I am getting the guages this week. Need to install. anyone no where I can't get the Factory Work Instructions.
There Pretty Nice. Looking. If I knew I could of got them on the build Mini site. I would of ordered them. There were acutally buried in a section of Audio. Under #5 build section.
Anyways. If you guys. Know or have done tyhis install pls get back to me
Thanks Guido.
Thanks Guido.
gauges
Hey John. I willl get them Tommorow. The cost on them is $325.00. I am not sure if it comes with hardware. I would think it does. Hopefully it just connects to a existing harness.
It looks real nice. Have you seen them.
Guido.
Guido.
Haven't seen them, but that is kinda steep for 2 guages.
I think I'll just do an autometer boost gauge although I'm not sure how that would coincide with the warranty.
Is doing work like installing aftermarket guages a no no?
I think I'll just do an autometer boost gauge although I'm not sure how that would coincide with the warranty.Is doing work like installing aftermarket guages a no no?
I believe I'd seen somewhere that the labor charge for dealer install was 1.5 hrs. I just picked up this kit myself (used from a NAM member on eBay) and believe he was sending the instructions with the kit. So, if you need them, let me know and I can scan it for you.
gauges
Hey Indi. Pls let me have a copy,thanks. I will be getting the guages today.
I heard the lighting is all the same. If someone goes after market. The lighting will be diffenrent that wont look right driving @ night.
I don't think the guages are that mouch. Was it hard to do.
Plus I am in the business so I got the guages @ my cost. less than what
Please send me a picture of how it looks in your car. Tahnks.
Guido
Guido
From Gomotoring.com
http://www.gomotoring.com/pdf/aux_ga...structions.pdf
Here's a pic of mine - I have the Promini gauge kit and had to figure out a lot of it myself as their instructions suck.
I have 15psi boost and oil pressure.
Thanks Guido.
Thanks Guido.
sadly, the needles don't light up.
included in the package, not shown is the replacement pod cover
I got mine 20% less then retail.
Originally Posted by aminicooper
You mean this OEM gauge?
This appears to be the same as the set I got. I agree about the night light condition--not so good. Also the needles are more red than orange and don't have silver discs in the center. Unsure about the usefulness of the voltmeter--always at 14. The cowling looks good and integrates the gauges with the tachometer. My mechanic said it was suprisingly complicated to install.
Yes sir, the lighting is very disappointing ... And my particular boost gauge is dimmer then the voltmeter, as shown below. At least the backlight color matches...
The new steering column cover/gauge holder is actually one molded black plastic piece - as shown below. The flash used in these pics over-emphasizes the color difference in the surrounding grey dash plastic. It is really not that noticeable. The column cover looks like a Mickey Mouse Ears Hat before you install it.
Hope this helps visualize whatcha get. My kit was installed at delivery by the dealership. There are more pics in my gallery...
Well lemme tell you having a BOOSt and Oil Pressure gauge near my tach is great.
Click here for a video to see the boost (to the right) go nuts. I have a few other videos on there......Oil pressure bounces around a lot as well, much better than voltage.
http://homepage.mac.com/machigane13/iMovieTheater7.html
I wish they did both the boost and OIL PRESSURE with the factory kit. I went with the Alta pod and Autometer Ultra Lites with oil pressure and boost/vacuum. They match the color of the OEM guages almost exactly. Illum is a lot better too. I will post pics when I get them installed.
I have a question for those of you who did this mod yourself - how the heck did you get the Tach reinstalled? Man, my hands aren't even big and getting those two darned screws back in has been a major pain in the rear.
Up to that point, everything was going very well.
The gauges aren't very bright, that's for sure. Do people know if there is anyway to make them brighter?
To make the lighting better, you can get LED 194 bulbs. I ordered red autometer bulbs from summitracing.com when I ordered my voltmeter. The amber ones don't match the orange color of the stock lights at all. The new LED bulbs are WAY brighter than the ones that came with the Autometer gauges (and I'm going to guess the same as the stock Mini gauges as well).
Can you give some part #s for these? I need to make a summit order, that would be great to get at the same time....
thanks!
thanks!
You should be able to find them if you enter "LED 194" in the search field on the Summit Racing site. I'm assuming these would need to be wired into the harness that comes with the OEM kit, correct? The ones in the OEM kit are little circuit boards w/ the LED that plugs into the end of the wiring harness.
While I would like a brighter gauge, I am not ready to rework my installation after just finally completing it. While it was a great learning experience, I'm not sure I want to play in all of those nooks and crannies of the MINI any time soon again.
A quick search for "led" on their site reveals this:
http://store.summitracing.com/defaul...5&autoview=sku
-jac
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
Navigation & Audio When adding an AUX input, does the HK stereo have a choice for AUX?
Norton70
Sep 11, 2015 12:16 PM
