Broken Lug Bolt
Old Dec 3, 2005 | 02:42 PM
mininh's Avatar
mininh
Broken Lug Bolt
I was putting my winter tires/wheels on this afternoon and One of the heads of my lug bolt just snapped off.
any ideas?
I was thinking that If the brake rotor isn't held on by these bolts it should come off just with the removal of the star bolt that is in there, then I would have enough bolt available to use an extractor. I don't think its cross threaded, so If I can just get enoough bolt I think I will be able to work it.
Anyone think this will work? Its to dark out for me to do this right now I am trying to get a game plan for tomorow.
advice is greatly apreciated
thanks
mininh
Old Dec 3, 2005 | 06:48 PM
90STX's Avatar
90STX
The brake rotor should come off okay. Good luck.
Scott
90SM
Old Dec 3, 2005 | 09:24 PM
kenchan's Avatar
kenchan
can you drill a hole in the broken lug and use an 'easy out' ?
do you use an impact gun on your lugs or did you just over torque it?
How much torque are you using? (typically i just use about 90lbs/ft)
Old Dec 4, 2005 | 08:47 AM
rrdusek's Avatar
rrdusek
definately pull the hubs off and i bet there'll be enough stud available that you can just back it out with vice grips. good luck.
Old Dec 4, 2005 | 08:51 AM
J0kER's Avatar
J0kER
DiTTO
Old Dec 4, 2005 | 09:11 AM
mininh's Avatar
mininh
yeah so its friggin snowin out right now I do not have a garage might put this off until tomorrow.
anyone ever take a hub off Is there any trick to it?
I generaly do not change / rotate myself, the shop I purchased my proxes 4s at includes rotation as part of the deal, and I think they just over torqued this one last time they were rotated. come to think of it I was only there for 10min so they probably just hit them with the impact wrench.
anyway going forward I will be rotating myself.
Old Dec 4, 2005 | 09:30 AM
J0kER's Avatar
J0kER
theres a big phillips flat head screw on the rotor, remove this and its all g00d from there carefull not to freeeezzzzeeee ur fingers off
yea d0od get a torque wrench & do it urself
Old Dec 4, 2005 | 10:45 AM
lsd05jcw's Avatar
lsd05jcw
whoopssssssssss
sorry to hear of broken luggggggggggggg
papawhiskey
Sep 14, 2015 05:47 PM
Sep 14, 2015 12:48 PM
Tires, Wheels & Brakes
Sep 14, 2015 11:34 AM
Sep 10, 2015 10:52 AM
