Drivetrain The $3.95 MCS CAI!
Old Nov 17, 2005 | 09:18 PM
not-so-rednwhitecooper
The $3.95 MCS CAI!
Well, i found the eBay MCS Intakes to be a fairly good bargin today.
I ordered it last week, shipped to me in 7 days, and it looks great. The lack of instructions makes it a bit hard to position, it looks like they use the tube on more than one car, its a simple 90 degree tube.
Nicely polished, the ends are all smooth, nothing jagged at all.
They ebvn include a nice bracket to relocate your BAT terminal to the firewall.
I had to cut my stock airbox in half to get this to fit, all that remains is the ECU holder, the rest was cut off.
Plenty of clearance now.
More pics tomorrow when my fake M7 Catch Can comes in!
Old Nov 17, 2005 | 10:04 PM
Tit's Avatar
Tit
If you drill big holes out of the back of the old airbox position, your air filter has access to the high pressure air at the base of the windscreen..
Old Nov 17, 2005 | 10:13 PM
hehe, yeah, tomorrows project, i just finished this at 12AM
I'm just going to cut the entire back wall out, less the places where it needs fastnening!
Old Nov 17, 2005 | 10:38 PM
J0kER's Avatar
J0kER
=0) hey,
d0oD!? whats the diameter on the tube & filter?
Old Nov 17, 2005 | 10:46 PM
Tit's Avatar
Tit
neat! looks like a bargain!!
you could also make a duct from the stock intake point at the front of the engine bay, to the area where the filter is...
I was thinking of making a 'lid' for my Alta CAI - a mate of mine here did a few small experiments and found that pressure around the filter builds up quicker when it's enclosed...
Old Nov 17, 2005 | 10:48 PM
whew, 2.5 inch i believe. i'll get my calipers out tomorrow and check
Old Nov 17, 2005 | 10:49 PM
i'm looking for someone who can mandrel bend me a tube past 90 degrees, or maybey i'll just have to make some.....hmm.....
Old Nov 17, 2005 | 11:06 PM
J0kER's Avatar
J0kER
"LID" ??
enclosed like the 'JCW' unit?......... or DINAN
Old Nov 17, 2005 | 11:36 PM
Tit's Avatar
Tit
no...literally like a flat square lid that sits over the alta heat shield - one you can just clip off to take the filter out....the idea could be scrapped if I decide to get a strut brace...
either way..it's fun making stuff....:smile:
Old Nov 17, 2005 | 11:46 PM
J0kER's Avatar
J0kER
right!! so like a 'JCW' or a 'dinan' =(enclosed box type) CAI...
u would be placin' another wall to the top of filter box... but wont the bottom of the bonnet do the same thin' when closed..!?
Old Nov 17, 2005 | 11:57 PM
MSFIT's Avatar
MSFIT
maybe
...like the bmp intake??
Originally Posted by joker
right!! so like a 'JCW' or a 'dinan' =enclosed box type CAI...
Old Nov 17, 2005 | 11:59 PM
J0kER's Avatar
J0kER
i wuz thinkin' to hard
ohhhhhhhhhhh ooooookaayyyy...............
Old Nov 18, 2005 | 12:01 AM
J0kER's Avatar
J0kER
..........=0)/
no,
not it!!
He said "flat square lid"
Old Nov 18, 2005 | 12:07 AM
MSFIT's Avatar
MSFIT
no,
not it!!
ooo..hahaha...i get it...
Old Nov 18, 2005 | 12:48 AM
Tit's Avatar
Tit
yeah..hahaah....
I'm not so sure the CAI seals properly on the underside of the bonnet...
I have to say - it's more a little fabricating fun, than me hoping to squeeze another 0.1hp out of my car...:smile:
Old Nov 18, 2005 | 05:35 AM
BuckeyeMCS's Avatar
BuckeyeMCS
That is a heck of a deal! looks good too.
Old Nov 18, 2005 | 06:35 AM
Bahamabart's Avatar
Bahamabart
While drilling out the back will give you access to the air from the air vents - it is NOT HIGH PRESSURE. It does however at low speeds allow the intake to draw air from theer instead of sucking it through the factory feed, thereby creating less of a straw effect.
Old Nov 18, 2005 | 06:44 AM
Fangio's Avatar
Fangio
I don't know what the tube is made out of but I would be sure to check the inside for rust. Eurosport had some CAIs out for VWs that would rust and reek havoc and MAF sensors.
Old Nov 18, 2005 | 06:46 AM
mdsbrain's Avatar
mdsbrain
Why not just remove the partition altogether? Thats what most of us with Alta CAI do and its allows for more noise Does it create more hp...I don't know.
Old Nov 18, 2005 | 07:34 AM
Stricks's Avatar
Stricks
Just what I was asking myself...
Old Nov 18, 2005 | 08:33 AM
Bahamabart's Avatar
Bahamabart
anything that facilitates the inhale - will help. I will assume that most aid comes from the free'er fliter (like alta or ITG) but when you are not at speed getting air forced to your filter the engine has to suck itlike a straw. The whole in the back lightens that straw effect.
every little bit helps.
Old Nov 18, 2005 | 08:45 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
$3.95, eh? Let me guess, $22 shipping?
Is the end of the filter open or closed?
Old Nov 18, 2005 | 09:10 AM
minibeel's Avatar
minibeel
Coordinator :: PDX MINI
If that rear wall has a big hole in it or is removed, would water get onto the filter--like from rain/washing?
dan
Old Nov 18, 2005 | 09:18 AM
hahaha, yep you got it!
closed end. its not staying long. K&N replacement will be on soon.
Old Nov 18, 2005 | 12:55 PM
chilimac's Avatar
chilimac
why
someone posted this a few threads up. I am a little confused. why would you remove the partion.. i am assuming, dangerous to assume, that you mean the metal box with the three walls that wrap around the cone and seal to the hood. If that is the partion you are talking about removing, that invalidates almost all the reasons of getting CAI, cold air intake. It is to ensure that the motor gets the cooler air from the little inlet outside of the windshield and in front of the driver. By openning the partitions yes it will take more air but it will be HOT hence useless for HP production. Kind a similar to the reason why the cars bog down on the track in summer months and people have water spraying systems installed. Cool air is good air for superchrgers.
