Drivetrain The $3.95 MCS CAI!
Old Nov 21, 2005 | 05:10 PM
  #76
fishbulb's Avatar
fishbulb
Thanks...we each have our reasons for upgrades! BTW, how is the sound with this guy?
For me, I don't think I want to chop the stock air box. I never seem to know when i want to return something back to the way it was for some reason or another. Thank you for pointing out that you had to do that in order to make it fit.
-jac
Originally Posted by not-so-rednwhitecooper
well, i dont care about any gains in horsepower, or any issues with it sucking warm air.
I bought it for the sound and the slight MPG increase.
its a very nice tight kit for the few dollars i payed for it, although i had to hack up some parts (stock airbox) to get it to fit in there properly and i had to make a new battery terminal hangar.
Old Nov 21, 2005 | 05:40 PM
  #77
Tit's Avatar
Tit
There's no real need to 'chop' anything, if you don't want to....
Buy the kit, and make up a shield from aluminium or something in your garage....you can work around the shape of the airbox's base....as for the rear portion of the airbox, that comes out without chopping too....
For $4 you can't go wrong (well..unless it damages something...)...if it goes to custard, just give it as a gift to your closest ricer friend!
Old Nov 21, 2005 | 07:04 PM
  #78
J0kER's Avatar
J0kER
or sell it to them for 20.oobux and make back the money +. ..
Old Nov 21, 2005 | 07:14 PM
  #79
you need to either remove the box completely ( not possible, you needd the ECU holder) or hack it in half to get it to fit.
the tube it at an angle and the length is just right to where it doesnt pit correctly if you dont remove the stock box.
theres so issues with chopping up a stock box, they are laying around evrywhere and would be cheap to pick up if you ever needed to put it back to stock.
Old Nov 22, 2005 | 01:31 AM
  #80
Tit's Avatar
Tit
Hmm...I didn't have to cut anything to put in the Alta....and left the base of the airbox in there....my ECU is in it's own enclosure....
A bit like this - the base is still in there:
Old Dec 2, 2005 | 06:03 PM
  #81
the ECU holder is molded to the lower part of the airbox.
to put my setup in, you needed to get rid of the bottom part of the airbox completely, but leave the ECU holder. so, cut them in half, problem solved. and mine cost a full $200 less!
Old Dec 2, 2005 | 07:32 PM
  #82
Kentiki's Avatar
Kentiki
I recently fooled around with the airbox, and in an attempt to keep it looking stock, but performing/sounding aftermarket, I used a cone filter i had on my old MC, and rigged it up inside the stock box, thus keeping it a CAI and using a better-flowing (i think) filter.
It sounded better with the box top off, now fully enclosed it sounds stock. I think I'm gonna cut out the back so the filter directly accesses the cowl vent.
Old Dec 2, 2005 | 07:37 PM
  #83
that what i was going to try and do, but gave up on it.
i was going to insert a sleve into the stock inlet for the air filter so you could slip a filter over it. then cut out the top of the box. i might mess around with that sometime down the road, we'll see.
Old Dec 3, 2005 | 06:35 PM
  #84
Kentiki's Avatar
Kentiki
Cut out the top of the box, that sounds pretty interesting. I used a PVC elbow to connect the filter to the hole in the box top leading to the throttle body. It was a PITA! Still feels better than stock tho. I want to cut out the back of the box and the wall behind it, tomorrow if I get any time!:impatient
Old Dec 3, 2005 | 08:39 PM
  #85
well, when i get my hands on an airbox, i'll try and do a few different things with it.
i'll keep everyone updated with my progress.
wildwestrider
Dec 27, 2015 08:20 PM
ej
Nov 17, 2015 09:21 PM
renchjeep
Sep 6, 2015 01:54 PM
