Interior/Exterior Black S Side Marker Vents?
Old Feb 5, 2003 | 07:43 AM
0wen0's Avatar
0wen0
Has anyone seen black S side marker vents? Any ideas on how to make them black? The thought of spray paint crossed my mind, but it doesn't seem like it would be very durable.
I think it would like really good. The black went with the red S!
Old Feb 5, 2003 | 07:50 AM
Davbret's Avatar
Davbret
You could customize the heck out them for ~$30:
-one can of plastic primer with elastisers
-one can of black paint (color coded to the black mirror/tops on the MINI) with elastisers
Both can be bought online at http://www.towerpaint.com. Comes in a spray can with a special nozzle that gives a wide pattern spray. Would be very easy to give a coat of primer, then a coat of black.
R
Old Feb 5, 2003 | 08:04 AM
0wen0's Avatar
0wen0
Sweet thanks!
Old Feb 5, 2003 | 08:21 AM
0wen0's Avatar
0wen0
What is the name of plastic primer? I can't find anything that fits your description on towerpaint. Also, do you know what the paint code is for that black?
Thanks in advance
Old Feb 5, 2003 | 08:42 AM
koolmini's Avatar
koolmini
take a picture when your done painting them,
i'm interested and would like to see the finished product
Old Feb 5, 2003 | 12:31 PM
Albert's Avatar
Albert
I'm having my S grilles painted black by a local body shop. My main concern about not doing it myself is the possibility of the paint not holding very well against the slick chrome surface. The body shop plans to sand blast and agitate the surface to provide some more "bite".
After removing the side grilles from the car, carefully remove the black perforated screen from the back of the grille. At that point, you'll notice that the "S" can be removed from the body of the grille. Furthermore, you can even remove the surface of the "S" from the rest of its body. You'll end up with 3 convenient pieces (minus the perforated screen) which make it much easier to spray, since there's now less crevices to deal with.
I also recently had a custom decal specialist make me some replacement colors for the "S". Since I have a black/black MCS w/lapis blue interior, I plan on replacing my red S with a blue one. :smile:
Also, I wanted to let you guys know that the decal guy plans to make many more of these S's in different colors (including carbon fiber) for sale. PM me if there's interest.
Old Feb 5, 2003 | 12:56 PM
0wen0's Avatar
0wen0
I'm probably not going to tackle this for a few weeks at least. I will post pics when I do complete it though.
Old Feb 5, 2003 | 12:57 PM
0wen0's Avatar
0wen0
Just out of curiosity, what did they quote you to paint them?
Old Feb 5, 2003 | 01:50 PM
Davbret's Avatar
Davbret
Just sand them with a high number grit (like 500+) and you'll be fine. As for the primer...you can call them and tell them what you are doing and they'll suggest what you need. Just tell them you need a primer to go over plastic with chroming which you'd sanded for some bite. They suggest a primer with plastisers. Call your dealer for the black paint code.
R
Old Feb 5, 2003 | 04:53 PM
Albert's Avatar
Albert
Around $50 I think.
boostedhaze
Jan 2, 2018 07:26 PM
Shane Wendel
Aug 21, 2015 01:04 PM
cm.d
Aug 19, 2015 08:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
