Drivetrain Will the Pilo Racing header throw any codes?
No codes from headers per se....
but if you drop the cat, you will get a code due to cat failure. That's what the second 02 sensor is there to detect. There are little modules that you can plug in to make the system "think" it's working. It fakes the heater load, and the output of the sensor that indicates clean air. This isn't allowable for street driving, and is actually a violation of federal smog equipment laws, but then so is adding a header.
I don't think the car goes to limp mode with a cat failure code.
Hope this helps...
Matt
Hope this helps...
Matt
I have seen them from Mini vendors....
Originally Posted by markbradford
I have seen the cat-delete interfaces on other cars, but do you know if anyone makes one for the Mini?
Matt
Yea, if you remove the cat you will get a code and the "Check engine" light will come on within 10 miles of driving it. It will not make the car run any different as the computer takes it's info from that first censer before the cat.
You will notice a difference though in performance without the cat.
Originally Posted by red rage
WHAT? I CAN"T HEAR ANYMORE, I HAVE NO CAT !!!
:impatient
:impatient
:impatient Tell me about it. My other car is basically dead and while I'm looking for another, I'm driving the Mini on the road. Minimanis header, no cat, Miltek resonator into a 3" Flowmaster 40 series.
I'm sorry, did you say something?
I should take a photo of this actually as I come straight through and exit with a single 4" resonated tip through where the backup light was. Will be building a rear defuser this winter if I continue with this car.
OPtimally I''d like to be able to swap the cat or test pipe in and out at will. Is this a feasible solution if I got an OBX header? How accessible is the cat on this car? I installed my Milltek exhaust but I can't remember how accessible the leading edge of the cat is.
The Madness 2 Header can be had with both pipes ....
But it does fetch a high price, it might be THE ticket
BUT the optimal setup, according to George at Madness is the Borla street exhaust with the madness header, which would mean even more $$$$$
The attraction of the OBX one is hte possible $/hp ratio. $175 plus a straight pipe to swap in = $300 max.
BUT I haven't seen the answer to a pipe or CAT that is the one to add to the OBX to keep it quiet, for a daily driver
Phil
Pilo is about to release a V2 header with removable CAT and test pipe that will start around $250 with test pipe and obviously more once CAT is available. expect this to be THE price leader once it hits market.
I assume that bolting the stock cat in is also an option?
can one of u knowledgeable peeps help me with this problem?
ive got the miltek cat back.. love the exhaust.. but frankly its not loud enough.. what can i do to make it louder ? (excluding the option of getting a miltek header which is waaaaay out of my budget )
thanks.
thanks.
Colt45Magnus
Aug 13, 2015 11:18 AM
Aug 12, 2015 01:24 PM
Aug 7, 2015 09:51 AM
