Suspension rear sway bar installion cost
I charge $80 to install a rear sway bar, and give discounts if your doing springs at the same time.
hope that helps.:smile:
Originally Posted by rick714
Hi,
What does it cost to install a rear sway bar at the dealer?
Rick
Rick
You should to it yourself. But if you insist on getting someone else to do it, take it to a tuner. It's cheaper, and work is done better. Or get a club member to do it. Assuming that youre in a club.
Or better yet have it installed at the 4th annual MINIs On the Dragon!
There are pleanty of Mini owners in your area that should be able to hook you up. If not I know there is a shop in Long Beach that could do it a lot less than the dealer. Try Johnny's Auto Clinic in San Pedro if no one else comes thru for you.
Outmotoring and Webbmotorsports both have real good instructions. Like I mentioned in my exhaust install thread I posted the other day. I don't usually do mechanical work on cars. I'm mechanically inclined but lack the confidence in doing things of this nature for the most part. With the help of these instructions, I put on an exhaust this past Friday and had two friends over to help me with adding a swaybar Sunday. Just take your time and it all works out good in the end. I was actually amazed at how easy it was once it was finished. The best thing I've got from it so far besides the handling is knowing, and being able to say, I did it.
It makes you feel all warm fuzzy inside.....well, maybe that was the alcohol.
I live in San Diego and can help for free. I have installed 2 before its really easy. Plus we have a couple clubs in the area with a bunch of people more than willing to help. If you want info on the club or help with the install PM me and I will give you my number.
Grendel...thanks for the offer.
I just found out my mini is being built today.
Should be here in about 2 months.
Spec:
2006 CR/W w/JCW; English Leather; red interior; R99 polished Rims; Chrome int pck; Chrono pck; Upgraded Stereo....
Future mods:
Rear sway bar; maybe MTM software
Spec:
Future mods:
Do they have dealers to do this at the Dragon? Do you have the website for the "minis on the dragon"?
Originally Posted by DrDiff
Nothing like a Club Tech session on rear sway bars!!
Spec:
I did mine for 1 hour labor (75).
If paying by the hour, it pays to get someone that has done it before because there are short cuts. Acually there shoud be a install thread some where around here. In sum, once the rear tires are removed, you actually loosen the entire rear suspension/frame and drop it a bit, you loosen gas taken as well and then the bar can actually be slide out one of the the wheel wells.
Someone with experience makes this look really easy.
Hey Bahamabart,
Who in miami did your for 1 hr labor. I need one installed
If you feel like cutting through your stock bar(we have about 200 stock ones if you want one), you dont have to take out either struts or drop the subframe. Our endlinks are removable, so the bar can be put in with ease. Here is a link to the Webb Motorsports Extreme Swaybar if you want to check it out. If you have any questions on installs or the bar, feel free to PM me or call the shop(303-683-4424).
-Brian
-Brian
Swaybar installation costs:
1 floor jack ($20-100 depending on store/quality)
2 jack stands (~ $15)
1 mechanics tool set US & Metric (Anywhere between $40-100, depending on store/quality)
1 torque wrench to torque your wheels back on to 88 ft lbs. ($15-30)
1 How to install a swaybar guide (Webb Motorsport forums - free)
Originally Posted by lexlow
Hey Bahamabart,
I used MYMINI (www.myminiparts.com) Peter coordinated w/ REDLINE next door. They know what they are doing 1 hour max.(75 bucks) and you get to hand w/ Peter, BS and look at a bunch of Mini parts. Worth the drive.
its only 30 minutes from my job.
15 in the mini
Thanks, Bahamabart.
Hope to see u out there!
I was lucky enough to have a friend in my local group who autox's and was both knowledgeable and willing to install my rear sway bar (H-sport adjustable 19mm).. it took him maybe an hour, perhaps less.
But I have a front sway bar (H&R) though that I got as a freebee from my dealer that I have not had installed yet- I gather it's a much bigger deal because of the drivetrain. (well duh I guess) 3 hours+ and technical knowledge a must-?
Hi,
Rick
Rick
You don't need your dealer to do a rear swaybar install.
It can take about 60 to 90 minutes so the $70-90 estimate is fine.
Your dealership rates for labor are much higher than any garage or tuning shop and they won't do a better job at the install although if you bought the rear swaybar from the dealer you might be able to get some sort of warranty from the dealer if they also did the install however rear swaybars generally are very solid performers and are trouble free.
The problem doing a rear swaybar install yourself is the hassle working on your back under the car with just jackstands. If you have a lift it is so much better and easier. This helps keep the install time closer to one hour and saves on labor costs.
