Interior/Exterior Front Grille Removal DIY??
Old Oct 1, 2005 | 06:54 AM
mellow's Avatar
mellow
Thought I saw a DIY on how to remove the upper front grille on an MCS but can't find it now.
Anyone know where to find it or provide the steps to remove.
Thanks!!
Old Oct 1, 2005 | 07:14 AM
L8RG8R's Avatar
L8RG8R
aero kit install
try this...
https://www.northamericanmotoring.co...ad.php?t=38902
Old Oct 1, 2005 | 08:37 AM
Nuff's Avatar
Nuff
Upper front grill removal
Thanks!!
Do a search for "aero grill" and you'll find instructions on removing the front grill.
Removing the upper front grill removal is pretty simple (in concept). There are a series of 10mm self tapping nuts and washers that need to be removed. Once removed, the upper front grill just comes off.
The problem is that the self tapping nuts are threaded into plastic posts that are part of the upper grill. It can be difficult to "unscrew" them since the threads are not particularly big. You need to use a thin flat head screw driver and wedge it between above the washer to apply pressure to the self tapping nuts while they are being removed. Be careful not to apply too much pressure or you will snap off the plastic post. If you are removing the upper grill to install a black aero grill then breaking off the posts won't matter. But if you ever want to put the old chrome grill back on it will be a lot more difficult without those posts.
The screws on the top edge of the upper grill are the most difficult to get out since they are harder to access.
Good luck.
Old Aug 12, 2009 | 10:59 PM
PowerPig's Avatar
PowerPig
I've just done something like this - mat black!
Those nuts under the grill... The f* cheapest solution I've ever seen!
Old Aug 13, 2009 | 10:37 AM
Jonshungry's Avatar
Jonshungry
And if you are putting it back together using the original chrome grille..
Use skinny zip-ties instead of trying to get those nuts back on
Old Aug 13, 2009 | 11:51 AM
BlueMolecule's Avatar
BlueMolecule
WORD! All do it 4 the weekend! TNXaLOT!
Old Feb 24, 2010 | 01:24 PM
burley's Avatar
burley
Good advice! Anyone have thoughts on a good way to remove the lower OEM chrome grill?
Old Feb 24, 2010 | 01:29 PM
JohnnyVillan's Avatar
JohnnyVillan
The one in the bumper? It just pops out from the back.
Old Feb 24, 2010 | 02:00 PM
Capt_bj's Avatar
Capt_bj
The lower grill is two pieces. The outer rim piece is held in with tabs, fitting into slots & can be pulled out. The center slat is a part of the bumper cover with a chrome cover piece stuck on with double sided tape on an S. I like to heat this with a strong hair drier or heat gun to soften the glue then slowly work it off. Remaining tape can be gotten with GooGone, GoofOff or WD-40.
The DIY for the Aero Grill mod recommends taking the entire bumper cover off to do the mod. Doing this, which is not difficult, allows you to work from the back which I find provides a buffer for any slips: scratches on the back of the bumer cover don't distress most folks.
Old Feb 26, 2010 | 05:07 AM
oxtox's Avatar
oxtox
sorry i just noticed this thread. m7 has great install pics for the grilles
http://www.grillcraft.com/installs/i...install_id=166
thanks m7
Old Feb 26, 2010 | 05:37 AM
burley's Avatar
burley
thanks m7
Thats PERFECT!! Thanks!
Old Feb 26, 2010 | 07:31 PM
oxtox's Avatar
oxtox
glad i could help
Old Feb 13, 2014 | 12:44 AM
famguy's Avatar
famguy
I did just as Capt_bj wrote. I pulled it of without any trouble at all. Just do it carefully.
boostedhaze
Jan 2, 2018 07:26 PM
wkp1219
Nov 13, 2015 07:52 AM
dcrna1
Aug 19, 2015 01:30 PM
FLYM1N1
Aug 15, 2015 11:20 AM
