Drivetrain Andy, what mods do you have on your car?
By Andy's request I am asking him what his mods are and what he has found to be most effective on his car. This is not a trap as I PMd him to keep this private. he requested a new thread or an email and I did not readily see his email address
This will probably help out a bit (andy can let us know how up to date it is)
http://www.ross-tech.net/andy/mini/mymini.html
Seems like a few engine mods, and only one suspension mod. :smile:
Andy....just curious, but why a 19mm sway instead of the usual 22(for an MCS that is....19 is typical on MC's)?
I currently have:
19% pulley
380 cc injectors
GIAC software
One-ball exhaust
HAI
16x7.5" Kosei K1
205/40-16 Falken Azenis RT-615
I went with the RDR 19mm mostly since I wanted a fairly mild reduction in understeer. The 19 mm on its middle setting seems to work great for that.
I should update my web page.
19% pulley
380 cc injectors
GIAC software
One-ball exhaust
HAI
16x7.5" Kosei K1
Originally Posted by andy@ross-tech.com
How is that possible? Look hard, you'll see it.
Andy, did you EVER put the Alta CAI back on or has it been HAI ever since the find?
Curious because I thought I saw the Alta CAI on in a recent pic. and remembered wondering why you might have reverted.
I've got the 205-15 G force Drag Radials on and with the ecu in limp home mode it wouldn't go over the line in third without hitting the rpm limiter
Now its in normal mode I'll be hitting 4th a lot earlier but I think I might have traction issues because of the extra hp, it had 128hp (86.2 @2447lb) the other weekend in limp home mode
Of course its all bs until that green light drops on Sunday
The K1's are good. I actually don't mind looks of the K1-TS and would rather have them due to the lighter weight. When I first installed the K1's, I neglected to use anti-sieze on the hub surfaces and threads and, as a result, one of the front wheels had its bolts loosen up (I wasn't able to get them tight enough, apparently). After that scary incident, I put a small amount of anti-sieze on each bolt and torqued them to spec - no problems since. I have read other reports of people having loose K1's as well and I have no explanation why these particular wheels would be succeptible to that condition, while other wheels would not.
What do you think of the Azenis? I want 215-45-16 for cornering and a little closer (but less than) stock gearing, but they are not due out till next quarter. Are they about 8% smaller than stock?
Could you post your picture/dimenstions of the pulley belt loosener again so I can try to make one? Did you make your own or just reinforce the factory one?
Thanks a lot.
Thanks a lot.
hi andy, was wondering what did you do as heat sheild box cover after you installed the helix short shifter ,i know some people had to remove it . did you make one or you just didnt reinstall it.
thanx
mikie
thanx
mikie
Thanks a lot.
Thanks a lot.
I got the factory belt tensioner tool and it broke on the second use, so I had a local shop weld it back together and make it purdy.
Originally Posted by MyPocketRocket
Andy, Do you still use the VGS on yours?
thanx
mikie
thanx
mikie
The gearing change of course does not show up on the speedo, but it's very noticeable in daily driving, especially compared to other pre-'04 MCS.
There is speedometer errror now, an indicated 77.7 mph is equivalent to a real 70 mph (GPS-verified). Stock it was only about 2 mph error. What I meant is that the speedo and tach still have the same relationship. Only one of them is lying a little bit now. :smile:
It was a goofy option that my car had. It looks like this:
Instead of the door panel being a textured black surface to match the rest of the plastic in the car, it is a smooth pale gray surface. Not the best shot, but I swapped it out for black panels from a Cooper:
Etrain
11
Aug 20, 2015 10:22 AM
