Plastic centering rings
Old Sep 3, 2005 | 10:44 AM
rlfletch's Avatar
rlfletch
I ordered a set of track wheels and tires from Alex at the tire rack. I was promised aluminum rings and it's written on my invoice but I received only the plastic ones. I e-mailed him but have received no response.
Anyone else get stuck with these plastic ones? Have any problems with them at the track?
Old Sep 3, 2005 | 11:12 AM
SRTech's Avatar
SRTech
Alex will take care of you. He has never failed to respond by phone or e-mail to me. Remember this is a holiday weekend.
Steve
Old Sep 3, 2005 | 11:37 AM
kenchan's Avatar
kenchan
yeh, Alex is my guy for wheels and tires. you can trust him, there was
probably some mix up in the transaction. The wheels i buy from tirerack
(mostly SSR's) comes with aluminum rings (usually made by mille).
Old Sep 3, 2005 | 12:36 PM
rlfletch's Avatar
rlfletch
I hope you guys are right, because I e-mailed him 4 days ago and there were other issues with the order. Maybe Katrina problems?
Old Sep 3, 2005 | 12:50 PM
LePew's Avatar
LePew
I had the same issue when I bought a set of Kosei K1's from TireRack / Alex. My mechanic said the plastic rings should work fine so I ran with them. Now up to three full days at the track with zero problems.
Old Sep 3, 2005 | 05:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
It's the holiday weekend right now but try emailing Alex again to let him know.
I had the same thing happen and Alex helped to get the metal rings to me to replace the plastic ones.
I prefer metal to plastic for track use due to the higher heat of the brakes and wheels. I've melted plastic rings before. For street and autocross the plastic rings are OK.
Old Sep 4, 2005 | 05:44 AM
norm03s's Avatar
norm03s
The rings are only a wheel mounting aid. You don't really need or have to have them. If you use the plastic one's at the track and run hard they will melt/distort as do the center caps. Just leave that stuff off, pay attention when mounting your wheels and torque on the lug bolts. Be sure to check lug bolt torque after first heat cycle.
Old Sep 6, 2005 | 12:31 PM
Alex@tirerack's Avatar
Alex@tirerack
RL Fletch -
Whats your email address?
Alex
Old Sep 9, 2005 | 10:10 PM
rlfletch's Avatar
rlfletch
New aluminium rings received from Tire Rack. Thanks for sending those out Alex!
Aug 19, 2015 12:51 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
