Collapsing Hose?
Old Aug 31, 2005 | 05:33 PM
moreorless's Avatar
moreorless
Collapsing Hose?
I've heard rumors of a breather (?) hose collapsiing due to heat on some of the early MCS cars. Trying to do a bit of preventative maitenance on my "02, So what's the scoop you all who are long in the tooth with this forum? :smile:
...Les
Old Aug 31, 2005 | 06:23 PM
kenchan's Avatar
kenchan
i think GreatBear had a fix for this somewhere. :smile:
if you take your car in for maintenance, the dealer should replace it
for you along with the rear latch for the boot.
Old Aug 31, 2005 | 06:45 PM
moreorless's Avatar
moreorless
Thanks.....
I'm a diy kinda guy so if I can find out what the hose issue is I'll fix it right up. They've fixed the latch (man that thing rattled). And took away v32, but that's a different thread and I don't want to get depressed all over again.
...Les
Old Aug 31, 2005 | 09:21 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Replace your PCV hose (lower left of valve cover when viewing engine from front of the car) with a 4 inch section of 3/8 fuel line hose. The hose supplied with the car on earlier models does not like the heat and oily vapors, it eventually balloons slightly in size and becomes soft, the vacuum will then suck the hose shut sometimes accompanied by a wheezing, whoopie cushion sound.
Very simple fix.
Old Sep 3, 2005 | 06:00 PM
moreorless's Avatar
moreorless
Originally Posted by Greatbear
Replace your PCV hose (lower left of valve cover when viewing engine from front of the car) with a...........
Very simple fix.
Thanks Boss!!!! :smile:
....Les
Old Sep 3, 2005 | 07:28 PM
MINIAC's Avatar
MINIAC
A recall on the crankcase breather line was issued to cars built from late June 2002 to late July 2003 ...
http://www.mini2.com/forum/showthrea...00#post1158100
Old Sep 4, 2005 | 08:05 AM
moreorless's Avatar
moreorless
Thanks Miniac.......
Mine is a May '02 build.......I just may replace it anyways.
:smile:
....Les
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
EVMini
Sep 28, 2015 10:20 AM
