Recommended Tire Pressure for 18" wheels
Old Aug 31, 2005 | 08:52 AM
mashngo's Avatar
mashngo
I've searched these threads, as well as owner's manual, but can't find anything on tire pressure for 18" wheels.
I'm running 38F, 35R but am open to suggestions from an expert.
Thanks in advance.
Old Aug 31, 2005 | 01:02 PM
glassintrepid's Avatar
glassintrepid
That is what im running as well.
Thanks in advance.
Old May 3, 2010 | 10:30 AM
RSvoodoo's Avatar
RSvoodoo
18" runflat vs std tires
I bought my '06S used and it has the 18" Works wheels on it. The sticker on the door is for 17"er's. and says 35# F/R.
Running non runflats now, and Tire Rack recommended to use the same presure as I did for the runflats. The dealer said to use38#'s in the runflats when I had them.
Bottom line, car seams to run OK w/35#s. Only have 2,XXX miles on tires so I can not tell a wear pattern yet.
This is what I know, if anyone has more info/advise I am alwasy open.
ab
Old May 3, 2010 | 11:26 AM
MiniCobra's Avatar
MiniCobra
Maximum Inflation Pressure
A tire's maximum inflation pressure is the highest "cold" inflation pressure that the tire is designed to contain. However the tire's maximum inflation pressure should only be used when called for on the vehicle's tire placard or in the vehicle's owners manual. It is also important to remember that the vehicle's recommended tire inflation pressure is always to be measured and set when the tire is "cold". Cold conditions are defined as early in the morning before the day's ambient temperature, sun's radiant heat or the heat generated while driving have caused the tire pressure to temporarily increase.
For the reasons indicated above, It is also normal to experience "hot" tire pressures that are up to 5 to 6 psi above the tire's recommended "cold" pressure during the day if the vehicle is parked in the sun or has been extensively driven. Therefore, if the vehicle's recommended "cold" inflation pressures correspond with the tire's maximum inflation pressure, it will often appear that too much tire pressure is present. However, this extra "hot" tire pressure is temporary and should NOT be bled off to return the tire pressure to within the maximum inflation pressure value branded on the tire. If the "cold" tire pressure was correctly set initially, the temporary "hot" tire pressure will have returned to the tire's maximum inflation pressure when next measured in "cold" conditions.
A tire's "maximum inflation pressure" may be different that the assigned tire pressure used to rate the tire's "maximum load". For example, while a P-metric sized standard load tire's maximum load is rated at 35 psi, many P-metric sized standard load performance and touring tires are designed to contain up to 44 psi (and are branded on their sidewalls accordingly). This additional range of inflation pressure (in this case, between 36 and 44 psi) has been provided to accommodate any unique handling, high speed and/or rolling resistance requirements determined by the tire and vehicle manufacturers. These unique tire pressures will be identified on the vehicle placard in the vehicle's owner's manual.
The tire's maximum inflation pressure is indicated in relatively small-sized print branded near the tire's bead (adjacent to the wheel) indicating the appropriate value. Because tires are global products, their maximum inflation pressure is branded on the tire in kilopascals (kPa) and pounds per square inch (psi). These values can also be found in the industry's tire load & inflation charts.
http://www.tirerack.com/tires/tirete...p#maxinflation
JamJam43087
Aug 16, 2015 02:02 PM
sabjcw
Aug 14, 2015 07:40 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
