Navigation & Audio Amp Install Tips!!
Old Aug 29, 2005 | 05:20 PM
Ivan1986's Avatar
Ivan1986
Amp Install Tips!!
hey everybody, i just got mini 05 S and wanna put in a 12" Xplod i have layin around. i was wondering if a sealed single truck box would sound ok. does anyone have a similar setup?? and also, i am gonna get some line converters and would like to know how to remove the stock non-HK stereo and wire the converters. any help would be greatly appreciated!!
thanks,
Ivan
Old Aug 30, 2005 | 01:22 AM
BluMiniMe's Avatar
BluMiniMe
Ivan,
Any box will sound good as long as its internal volume meets the needs of the sub. You sub manual should recommend a perferred sealed box size. As long as you can get real close to that size, a "truck" box will be fine.
A line leveler is pretty easy to install. It taps into either the front or rear speaker wires. Find a location where you would like to splice, and simply wire the input wires on the leveler to the +/- wires on left and right channels. On the rear channels, the + wires has a brown stripe, black strip is -. No need to remove the head unit, unless that's where you want to splice into the speaker wires.
Now just use a RCA patch cable from the leveler to your sub amp.
Old Aug 30, 2005 | 12:55 PM
Ivan1986's Avatar
Ivan1986
and where would the remote wire go to?
Old Aug 30, 2005 | 01:11 PM
mikeythemini's Avatar
mikeythemini
You can normally pick the amp remote up in the left rear boot cubby - thin white wire going up towards the roof aerial
Old Aug 30, 2005 | 01:26 PM
Ivan1986's Avatar
Ivan1986
Im gonna go and pick up some converters today. and where and what color are the wires i have to splice for the converters??
Old Aug 30, 2005 | 08:35 PM
BluMiniMe's Avatar
BluMiniMe
Try this. This should be help you find the correct wires on the rear of the radio. Like Mick suggests, I recommend you use the white wire. It is also present on the rear of the radio.
cheers
Old Sep 1, 2005 | 04:06 PM
Ivan1986's Avatar
Ivan1986
thanks y'all!!!! all the info helped and i installed it in like 1.5 hours. i got a custom box made to fit the boot and made specifically for the sub at Tweeter for $100 and it fit awesome and the sound is mindblowing!! im glad i didnt convince myself to get another 12" and get a dual box made. thanks again!!
Old Sep 1, 2005 | 09:05 PM
BluMiniMe's Avatar
BluMiniMe
Glad we could help!:smile:
Old Sep 2, 2005 | 04:17 AM
Wagnbat's Avatar
Wagnbat
WOW. I went to Tweeter to talk to them about this, and they said they wouldn't do it unless I bought the sub and/or amps from them, and then the lowest price they mentioned was $400 for a box. I walked out and havn't been back since.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ASRman
Aug 13, 2015 09:33 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
