Navigation & Audio Antenna connection a "Standard" one?
Old Aug 26, 2005 | 11:31 AM
SheaJeff's Avatar
SheaJeff
I want to install a 12 disc trunk mounted CD player that I have and it uses an FM modulator that connects to the back of a car radio through the antenna jack. Normally, I would pull the car antenna from the radio, plug it into the little box that cam with the CD player, then plug the CD player box back into the radio of the car. I've had this in two previous cars and it's worked fine.
I've read conflicting reports about the antenna conneciton on the back of the head unit in Minis.
Is it standard, or a Mini/BMW special shape/diameter/whatever?
If so, can I get adaptors anywhere?
If it matters, I have a 2004 MCS with the Harmon Kardon and Sirius unit.
Thanks for any help.
Old Aug 26, 2005 | 11:42 AM
not-so-rednwhitecooper
i believe the mini's use a unusual antenna hook up, like its integrated into the main plug.
FYI, the HK and standard HU's are all the same.
Old Aug 26, 2005 | 06:20 PM
mikeythemini's Avatar
mikeythemini
The Mini has a FAKRA aerial plugYou can connect your modulator using an adaptor
Old Aug 28, 2005 | 06:41 AM
SheaJeff's Avatar
SheaJeff
Thanks Mike.
Is this what I need?
https://www.newministuff.com/new/sho...uctshow&id=150
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
JAB 67
Sep 29, 2015 01:34 PM
buggyeye401
Sep 28, 2015 04:09 PM
krohm
Sep 28, 2015 12:16 PM
