Suspension Quick Q on Hsport comp rear bar (urgent)
Old Aug 22, 2005 | 07:29 PM
S1monLM's Avatar
S1monLM
Trying to install the rear bar on my car, but found there are 2 little bolts that comes with the bushing pkgs? Can anyone tell what's that for? Where do I screw the bolts?
Old Aug 22, 2005 | 07:33 PM
S1monLM's Avatar
S1monLM
Also, do I use the factory bolts to mount the brackets/bushings? They seems abit too short!
Old Aug 22, 2005 | 07:36 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Could the small bolts you refur to be the zerk fittings to lubricate the bushings? Is there a small hole in the middle of them?
Yes, the stock bolts should be fine to reuse.
Old Aug 22, 2005 | 07:46 PM
Smooth is Quik's Avatar
Smooth is Quik
small screws
If they are the zerk fittings, make darn sure you point them in the correct direction so you'll be able to lube them after the sway bar is installed without any interference.
Old Aug 22, 2005 | 07:56 PM
S1monLM's Avatar
S1monLM
Can anyone explain what's zerk fittings?
Old Aug 22, 2005 | 07:57 PM
ingsoc's Avatar
ingsoc
that's where you shoot grease into that type of bushing.
Old Aug 22, 2005 | 08:08 PM
S1monLM's Avatar
S1monLM
The stock bolts are way too short, has anyone tried using a longer bolts to mount the brackets?
Old Aug 22, 2005 | 08:12 PM
onasled's Avatar
onasled
Something must be wrong with how you are doing this. The stock bolts are fine.
This photo shows what you should have found in the box. Two of whats in the photo and the bar itself.
Old Aug 22, 2005 | 09:10 PM
kmickey's Avatar
kmickey
This might be helpful: check out this "how to".
http://store.webbmotorsports.com/for...topic.php?t=14
Old Aug 23, 2005 | 12:31 PM
S1monLM's Avatar
S1monLM
Got the bar on last night, the rear is making loud clunking noise, I might have to re-install it again later this afternoon.
Old Aug 23, 2005 | 12:52 PM
lsd05jcw's Avatar
lsd05jcw
H-sport comp bar
The stock bushing bolts are an acceptable length, but difficult to tighten down if you have the stabilizer endlinks connected already or if you tighten one side all the way down before tightening the other side.. also if you tighten the bushing bolts while you have the subframe dropped it much easier to tighten... I'd suggest using a bit of locktight on the the bushing bolts too.. one of mine worked loose, and ended up causing a clunking sound as the bar hit the underside of my car.... An issue I had was that the bushing ended up touching a body tab on my 2005, but I left it, instead of grinding or removing any undercoating... good luck, it will work out.....
Old Aug 23, 2005 | 06:42 PM
S1monLM's Avatar
S1monLM
How did you guys center the bar?
Old Aug 23, 2005 | 07:04 PM
kapps's Avatar
kapps
Just get it close by eye. You should be able to get a good sense of where the center is by looking from behind the car. As long as it's not way off (and hitting the inside of the wheel or something of that nature), it should wiggle itself center when you drive it.
Old Aug 24, 2005 | 06:09 AM
lsd05jcw's Avatar
lsd05jcw
bar center
I took a piece of string, and used as a flexible measuring tool and played with bar centering until the length of string from the swaybar bushing to the bar end appeared to be the same on both sides..... not perfect but got length about the same... It doesn't have to be exact...
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
PhoenixR61
Aug 21, 2015 07:40 AM
OZMDD
Aug 17, 2015 02:53 PM
