Navigation & Audio How do you run speaker cable into the doors?
Old Aug 20, 2005 | 03:00 PM
markbradford's Avatar
markbradford
I took a few minutes to examine the single entry point (via rubber tube/grommet) into the door for speaker wire and it looks impossible! Do I need to remove the doors to get some decent speaker wire in there?
Old Aug 20, 2005 | 03:38 PM
markbradford
Ok just realized it is impossible unless you drill a hole through the body inside the door frame. That blows.
Old Aug 20, 2005 | 03:43 PM
not-so-rednwhitecooper
from what i hear, you can just drill out the unused holes in the block of wires and run hem thru there.....
Old Aug 20, 2005 | 03:47 PM
or just go buy a new tube that runs between the doors and open two holes below the exising ones so you can have anohter full rount for wires to go thru....
ok, i guess thats an understandable explanation....
Old Aug 20, 2005 | 03:54 PM
markbradford
My problem is that on my 2005 all of the stock harness pin points appear to be in use - there's no room for me to drill out the stock harness without losing some existing pins.
Old Aug 20, 2005 | 03:55 PM
bah, you probably dont need all that crap!
(Please dont take me seriously, i wont be responsible for any actions taken) lol
Old Aug 20, 2005 | 05:37 PM
markbradford
I drilled a hole just aft of the harness, through the plastic harness housing. My speaker wire is braided with an external sheath, so it should be fine just zip tied to the stock rubber tubed bundle.
There was no way I was running power from a PPI amp to a Diamond Audio Hex component set through those dinky little stock wires! :-P
Old Aug 20, 2005 | 05:47 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Good choice
Let us know how it goes. Where are you gonna put the crossovers? I have yet to find a place for mine that i KNOW will work. Still gotta test i guess
Old Aug 20, 2005 | 06:41 PM
kenchan's Avatar
kenchan
any picts of the harness install? :smile:
Old Aug 21, 2005 | 01:18 AM
markbradford
Originally Posted by RallyMINI
Good choice
Going to have to put em in the doors I guess. I'd hoped to put them in the rear side panels just east and west of the boot, but there was no way that I was getting two sets of wires per door squeezed in.
The Diamond crossovers are *HUGE*. I mean RIDICULOUSLY HUGE. Good for sound quality and longevity but awful for svelte placement. I'll probably end up double-sided-taping them to the outer door skin, behind the window, approximately mid-door. *shrug*
Old Aug 21, 2005 | 07:38 AM
kenchan's Avatar
kenchan
guess not...
Old Aug 21, 2005 | 07:56 AM
DevilMini's Avatar
DevilMini
I mounted mine in the boot and ran a plenium type 4 conductor from monster cable out to the doors. The wire is standard 12g and I did the same as you with the drill out and zip tie. Works well and the sound is just fantastic!
BTW Nice choice in comps. I went with a custom Seas/vifa set up myself.
Let us know how it sounds when complete!!
DM
woodstudio
Mar 15, 2020 08:28 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
