Newb question... front, rear, or both brake pads and rotors
Old Aug 18, 2005 | 03:31 PM
Ranzo's Avatar
Ranzo
Newb question... brake pads and rotors
Hey guys,
I was just wondering what is are the advantages and disadvantages of setting up brake pads and rotors either just in the front, or just in the rear, or both front and rear.
I do mostly street driving and some canyon carving, I got 15" Momos. Would you guys recommend a brake kit or other brake modification set ups?
If so any recommendations for good quality products that's got more bang for the buck?
Your input is much appreciated! Thanks!
Randy
Old Aug 19, 2005 | 08:46 AM
Alex@tirerack's Avatar
Alex@tirerack
Powerslot Cryogentic Rotors with Hawk HPS pads - a great setup for spirited street driving, autocross - and light track work. $618 plus shipping.
Alex
Old Aug 19, 2005 | 10:46 AM
Ranzo's Avatar
Ranzo
Do I get the front ones or do I get the rear ones or do I get both? What are the advantages and disadvantage of each option? I see a lot of cars with just the front brake pads... Thanks!
Randy
Old Aug 19, 2005 | 10:51 AM
kyriian's Avatar
kyriian
Originally Posted by Ranzo
Do I get the front ones or do I get the rear ones or do I get both? What are the advantages and disadvantage of each option? I see a lot of cars with just the front brake pad...
if you run a different temp compound on your brakes, you can have too much bite in the front... most people will probably recommend doing all 4...
that said, on a track, some people swap to higher performance pads up front as it is the one getting the load done... the ferodo ds3000/2500 combo on the track seems like a good combo
Old Aug 19, 2005 | 06:42 PM
supersand's Avatar
supersand
I think the reasoning for upgrading the front brakes is that under braking the cars weight shifts to the front wheels and this is where the maximum amount of tire grip is (with the car's weight shifted forward) and consequently where the most braking force can be applied before the tires loose grip and lock up. I'm not sure about the biasing (front/rear division of braking force) of cars with a BBK up front and stock brakes on the rear, but I imagine this is something the engineers/ designers of aftermarket kits take into consideration, so your probably alright just upgrading the fronts.... it seems that lots of people here on NAM have upgraded just the fronts without any problems.
Erik
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
fjork_duf
Aug 16, 2015 04:38 PM
