Leaky Antenna. Please Help!
Old Aug 18, 2005 | 07:55 AM
Todd05HBS's Avatar
Todd05HBS
I don't normally drive in the rain, but the other day it happend. I discovered my antenna has a leak. Water was leaking into the back seat. My antenna appears to be loose on the front side. Any ideas on how to tighten the thing myself? It's about a three hour trip to the dealer and it's not my daily driver- so there is no rush. Any help... Thanks in advance!
Old Aug 18, 2005 | 09:53 AM
searocko's Avatar
searocko
Do you have a sunroof? If so, there is a cap in the headliner just behind the sunroof that houses the motion sensor for the optional OEM alarm. Pull it off and you'll be able to see the nut for the antenna. It takes a 22mm socket but access is pretty tight. You probably could manage with an open end wrench.
If you don't have a sunroof then the only option is to drop the headliner.
The nut is located toward the rear of the antenna base making it easy for the front side to swivel if it's not tight enough.
Old Aug 19, 2005 | 06:41 PM
Todd05HBS's Avatar
Todd05HBS
I do have a sunroof. I looked under that cap and that nut didn't look like what I needed to tighten. I'll look again and thanks for the help!
patsum
26
May 29, 2021 06:29 PM
vetsvette
Oct 2, 2015 07:09 PM
simo711
Oct 1, 2015 05:36 AM
YoloSapien
Sep 25, 2015 07:12 AM
CooperT
R60/R61 Stock Problems/Issues
Sep 22, 2015 12:54 PM
