R50/53 Garage door opener option
Old Aug 16, 2005 | 09:13 PM
skywarrior's Avatar
skywarrior
Instead of shelling out for the order form #319 Universal Garage Door Opener for $200, I chose the aftermarket Flash2Pass Remote System costing $47. It is a transmitter module that you simple wire to your left headlight Hi Beam wire and attach the receiver to your grages interior receiver. Once you have done that, all you do is stroke your steering column hi-beam stalk twice, and if you are within 200 feet of you door receiver, the door will open. No need to carry around a door opener. To view it: www.f2pelectronics.com.
Old Aug 16, 2005 | 09:40 PM
C4's Avatar
C4
I got the factory installed Homelink transmitter as part of the $400 "Convenience Package". Clean, transparent and seamless integration. One of the best options in the MINI.
Old Aug 16, 2005 | 11:32 PM
BBCooper's Avatar
BBCooper
$10 option...
Howdy,
My solution to getting rid of the garage door "visor wart" was this..
The first challenge was to hide the remote in a functional location. I found there was enough space above sunroof switch behind the black plastic trim. I used some Velcro to keep the reomte from sliding when cornering and still make battery replacement easier in the future.
Before the final install, I connected a short run of wire between a separate small button (the push to activate kind) and the contacts on the remote. By mounting the reomte in this location, the easiest place to put the button was through the vented opening on the opposite side (I think this is the location for the microphone if you have the Bluetooth phone option). Depending on the button size, one can cut away some of the vent ribs to allow the button to be mounted right to that small plastic panel..
I have been using this for over a year now with no problems.. And if you don't know the button is there.. It is practically invisible..
For what its worth... Enjoy
Edited - added pics...
1st one is the viewed TOWARD the rear view mirror
2nd one is viewed AWAY from the rear view mirror
Attached Thumbnails Garage door opener option-dsc02684-b.jpg   Garage door opener option-dsc02689-b.jpg
Old Aug 16, 2005 | 11:35 PM
BBoy's Avatar
BBoy
Sounds like a cool set up. Do you have any pics?
Old Aug 16, 2005 | 11:41 PM
Eric_Rowland's Avatar
Eric_Rowland
Even better, for about the same price, you can get an "Auto-up Module" from Ian Cull, attach your garage door opener AND get auto up windows!
No connection, just a very happy customer!
Old Aug 17, 2005 | 05:29 AM
francisk's Avatar
francisk
Originally Posted by BBCooper
Howdy,
I did it the same way.. only a button located on the microphone area. Looks nice and clean.
Old Aug 17, 2005 | 05:35 AM
drdave's Avatar
drdave
I have also been looking for something to replace my TWO garage remotes. I have Homelink in my other vehicle and love it. The Homelink mirror for the MINI is only available for 2005 models so that isn't viable for me.
I've purchased a couple of used Homelink modules (2 different models) and installed one with no luck so far. I am gonna try the other one when I get the time.
Old Aug 17, 2005 | 08:44 AM
mr_edly's Avatar
mr_edly
"Auto-Up MINI circuit" can be ordered with two garage door opener circuits.
Ian Cull's "Auto-Up MINI circuit" solves the annoyance of having to hold the window toggle switch up to close windows in a MINI - especially troublesome with a manual transmission when pulling away from a toll booth in wet weather!
You can order versions with BOTH track mode DSC and garage door opener, or with two garage door openers.
http://www.gbmini.net/MINIcircuit/in...tml#interested
Old Aug 17, 2005 | 10:44 AM
scooterboy's Avatar
scooterboy
Another vote for Ian's circuit.
Auto-up on the windows, and my unused toggle #2 (DSC/ASC) opens my garage door. Brilliant!
Old Feb 18, 2010 | 11:01 AM
kishg's Avatar
kishg
resurrecting an old thread, but can someone explain how they installed the garage door opener using ian's circuit?
Old Feb 18, 2010 | 11:08 AM
ECHO-313's Avatar
ECHO-313
Old Feb 18, 2010 | 11:20 AM
JIMINNI's Avatar
JIMINNI
Matt...AKA Dr. Obnxs is the new dealer for the Ian Cull circuit's. His company is, FES Auto. I just installed the "Auto up", love it I'm sure you can get the info you need there. Here is the link.
http://www.fes-auto.com/
Dec 23, 2015 10:36 AM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
SoCalledFriend
Aug 6, 2015 06:59 AM
