offset
Old Aug 6, 2005 | 06:50 PM
minimik's Avatar
minimik
offset
does anyone know for sure the right offset for a set of tuner wheels? I have a 05mcs and have heard it either +40 or +48. The set i want is +40.
Old Aug 6, 2005 | 07:45 PM
onasled's Avatar
onasled
40 should work but it really depends on what tires you plan on using and if you have lowered the car much
Old Aug 6, 2005 | 10:21 PM
Konky's Avatar
Konky
I thought our cars were 42 offset, but I'm probably wrong. Maybe it's the wheels I have on now are 42.
Old Aug 7, 2005 | 02:22 AM
aokdoug's Avatar
aokdoug
running 44 offset 1 inch drop with 215/35/18: no issues.
doug
Old Aug 7, 2005 | 05:27 AM
Joe Donovan's Avatar
Joe Donovan
MINI2 Forums
If not a member of MINI2 forums , you should look into it.
http://www.mini2.com/forum/faq.php?f...q_faq_bolt_etc The ET listing is the offset!
If you cant find the link , post again and I'll help
Joe D.:smile:
Old Aug 7, 2005 | 06:46 AM
Joe Donovan
Wheel Gallery
Here is another great thread, closed the posts but still open for viewing. Hopes this helps. Joe.
http://www.mini2.com/forum/showthrea...heel%20gallery
Old Aug 7, 2005 | 11:01 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
minimik,
You are looking for rims that are at least 15" or larger up to 20".
4x100 bolt pattern, MINI hub bore is 56.1mm
+48 mm is the stock offset for the MINI but it can varry a little down to +45
If you have the stock MC or MCS suspension you can use rims that are in the +37mm to +48mm offset range without rubbing.
If you have lowered your MINI you should look for rims that about +45mm offset although you can go to about +42mm and get only a little rubbing.
+40mm offset with a lowered suspension is likely to rub. You can minimize this chance if you install tires with a lower than stock outer tire diameter (24.4") such as the 215/40-17 for 17" rims. If you do get rubbing then you can use a dremmel tool to trim away the plastic that rubs on the inner rear wheel wells.
If you don't want to fuss with all this then talk to Alex@tirerack and visit tirerack.com and enter you have a MINI and it will give you the wheels that will fit OK so you can see the offsets that match. They assume you have stock suspension.
Old Aug 7, 2005 | 02:37 PM
minimik's Avatar
minimik
offset
Thank you everyone for your help. Was out of town, just got back. Your help is really helpful.
Thanks again
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
