Web Site?
Originally Posted by kaelaria
You are low on mouse fluid!
What the heck are you talking about? How about some detail...
This is what I am getting.
Parse error: parse error, unexpected '}' in /home/wecantdr/public_html/forum/includes/template.php(127) : eval()'d code on line 42
Well Kae I get this when I try to access the web site. It may be my settings because the base I am at does neat things to the fire wall but I doubt it.
www.wecantdrive.com/forum/portal.php
Art
Art
Originally Posted by Aquasar
What is wrong with the web site I can not get it to work?
Art
Art
Errors sorry for the double post
When the message forum does appear, meaning I get the afore mentioned error, I get the following error when trying to select a forum:
Template->make_filename(): Error - file does not exist
hope this helps
hope this helps
hope this helps
hope this helps
That version is about six patches out of date and contains a couple security holes, one of them being a template hack, and its been hacked. Those of you that have a different style on the board set as your default are getting in, and others that had the default are probably not, or vice versa.
http://www.phpbb.com/phpBB/viewtopic.php?f=14&t=302011
That link has the most current version if someone that can get in, or knows the admin, wants to pass it on to the admin of that site. I'm not on it, but am very familiar with phpBB. There is a script fix that will also probably need to be run to fix the problem before its patched to the current 2.0.16 version.
Dan
dutchhome
Sep 30, 2015 07:17 AM
