Autotap OBDII software
Old Jun 5, 2005 | 09:37 AM
Cooper S IRE's Avatar
Cooper S IRE
has anybody bought this software and got it to work with the Mini????
the reason I ask is I really like the fact that you can design the information display
Old Jun 7, 2005 | 08:40 AM
garretwp's Avatar
garretwp
I was looking into this kit as well, but I was also looking into [size=-1]www.autoenginuity.com has some nice features. Not sure what standard the Mini cooper uses, but I do not see why it would not work.
Garrett
[/size]
Old Jun 7, 2005 | 09:13 AM
SumWon's Avatar
SumWon
Do you have a link for us?
Old Jun 7, 2005 | 10:14 AM
garretwp's Avatar
garretwp
www.autotap.com
garrett
Old Jun 7, 2005 | 10:40 AM
asodestrom's Avatar
asodestrom
Garrett
[/size]
I have the autoenginuity kit and it works great. I chose it because of the availability of a wireless bluetooth link. I use it with my Tungsten T3 as well as with my laptop.
Old Jun 7, 2005 | 11:22 AM
SumWon's Avatar
SumWon
Looks interesting, but I would be concerned if that red box (lower right in the picture on top of the USB cable) is what hooks to the OBDII. Wouldn't that get in the drivers way on our cars since the OBDII port is below the steering wheel?
Old Jun 7, 2005 | 11:33 AM
garretwp's Avatar
garretwp
Only if you would want to do data logging on the car. But if your wanting to pull codes or any other diagnostics on the car, then I see it not being much of an issue. I think I am going to be placing an order for the autoenginuity kit as i like the feature where it can give you basic run numbers for 1/4 times, hp and torq. etc. Even though i already have a g-tech. I think it is worth the money in the long run.
Garrett
Old Jun 7, 2005 | 01:23 PM
SumWon's Avatar
SumWon
Well I would think that it would have to be hooked up to get the realtime gauges to work wouldn't it?
Old Jun 7, 2005 | 01:26 PM
Dr Obnxs's Avatar
Dr Obnxs
You can move the OBDII connector.
Then it won't be hitting your clutch foot. For those of you that have gone this way, what's your data rate? I have the CarChip E/X and it's a 5 second rep rate. Wayyyyyyy too slow. Seams that OBDII is a pretty slow interface. There's a streaming mode where it just sends the numbers over, but the software has to support it. That looks like it will get to better than a second if you aren't looking for too many variables.
Has anyone used a CAN bus logger for the Mini? This should be much faster.....
Thanks for anyone's help...
Matt
Old Jun 7, 2005 | 01:36 PM
doomsdaybob's Avatar
doomsdaybob
They list and recommend an extension cable for cars w/ the port under the drivers side dash.
Old Jun 7, 2005 | 03:18 PM
jaxkewl's Avatar
jaxkewl
this one is coming soon and as soon as it does im buying one. i used to own a jetta and i bought ross-tech's obdii adapter for vw and it worked great. great support also.
http://www.ross-tech.com/bim-com/comingsoon.html
Old Jun 7, 2005 | 09:17 PM
garretwp's Avatar
garretwp
What does ross tech have over the other scanners?
Garrett
Old Jun 8, 2005 | 12:38 AM
Cooper S IRE
Garrett
correct me if im wrong but the ross-tech system is not even released yet and will be in the Beta stages,
it will be a great tool for diagnostics and programming control modules
but that is some time away,
I was looking at the Autotap for the graphic display it offers
as I am working on a nice idea and want to extract as much info from the OBDII as I can and this is the only scan tool with a user defined GUI
Old Jun 8, 2005 | 04:48 AM
jaxkewl's Avatar
jaxkewl
Garrett
i can only tell u what i knew from the vw obdii scanner i bought for vw. it worked really well. it translated all the DTC codes into text. you could make graphs and stuff.
can any obdii scanner have the ability to change all the user settings on your mini? like follow me home lights, remote window open, auto unlock etc?
Old Jun 8, 2005 | 04:55 AM
Cooper S IRE
none that i know of this is why BiM COM and Vag Com are totally unique
Finhead
Electrical
Apr 12, 2019 04:05 PM
navybsn
Oct 5, 2018 04:42 PM
Pker
Apr 11, 2017 12:14 AM
rlp
Sep 11, 2015 03:28 PM
PSU 98
Sep 11, 2015 11:20 AM
