Autometer/ProMini Boost gauge accuracy
Old Jun 3, 2005 | 03:41 AM
SpiderX's Avatar
SpiderX
How accurate is this gauge? I have one and I'm wondering about its accuracy
Old Jun 3, 2005 | 09:16 PM
Ryephile's Avatar
Ryephile
An Autometer representative once told me their mechanical boost gauges should be within +/- 0.5 PSI. That said, where the tap is for the reading within the MINI's manifold makes a big difference, due to the crappy manifold design. You'll see a much bigger boost reading at the #1 cylinder than the downstream MAP sensor location (which is near the #4 cylinder).
Old Jun 4, 2005 | 03:17 AM
SpiderX's Avatar
SpiderX
which one should you use?
btw do you want to come to Atl to tune my car after the intake manifold and SC mod are installed?
I have added the Alta IC and CAI since the last tune
Old Jun 4, 2005 | 08:28 AM
Ryephile's Avatar
Ryephile
I don't think there's a gauge you should use, just whatever you like. I use an Ultra-lite 2 1/16" mechanical, as it matches the stock gauges fairly well.
also, PM sent
Old Jun 4, 2005 | 09:52 AM
SpiderX's Avatar
SpiderX
I meant which position do you use?
Sorry
also, PM sent
Old Jun 4, 2005 | 06:10 PM
002's Avatar
002
How much variation have you seen across the manifold?
Old Jun 4, 2005 | 08:44 PM
SpiderX's Avatar
SpiderX
also, PM sent
The reason I ask is that before adding the IC and the CAI I was getting 16 now I'm getting 15 and I am curious
Doc Pain
Oct 28, 2015 07:09 PM
Oct 1, 2015 12:13 PM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
