Coolant Level
Old May 31, 2005 | 05:24 PM
hyperblue1's Avatar
hyperblue1
Coolant Level
The plastic coolant resevoir on our 2005 MC only has about 1/2 inch in it. We know that it should be between the min and max. The car has 1900 miles on it. Our concern is where did the coolant go? Should I get it serviced as soon as possible? We are adding coolant/distilled water tonight because we don't want it to be dry in there. My husband checked the coolant level in the radiator and it is fine. Could it be a problem with the plastic resevoir? We are also concerned that it could be a bad gasket. Has anyone else experienced problems with the coolant level?
Old May 31, 2005 | 05:33 PM
Strom's Avatar
Strom
Mine was a little low today as well. I have about 2,600 miles on the odometer. Hopefully it's somewhat normal...
Old Jun 26, 2005 | 05:16 PM
ScurveS's Avatar
ScurveS
Be Cool...
I've added 50/50 coolant and water a couple of times in the last year. It only seems to take a cup or so to bring it back up to the correct level. I would guess that it isn't enough to worry about, but I would rather have it right. Either way, the temp gauge doesn't seem to change. I don't think you need to use distilled water. Bottled water works fine.
Jim
Old Jun 26, 2005 | 05:53 PM
lotsie's Avatar
lotsie
Get some coolant from your dealer.Mine just gives it to me premixed that I keep in one of the cubbys in the boot.
If the system is opened, it is hard to bleed out the air, so the level will drop for a week or so, as the air bleeds out the breather.
I have seen my tank go from max, to min. and back up in a day. Just keep some fluid handy, and add as needed.
I find my fluid needs topping up when the car has been serviced,for a week or 2, then it stays full for months.
Seems to be another of the "charms" of these cars
Old Jun 26, 2005 | 06:07 PM
onasled's Avatar
onasled
Originally Posted by hyperblue1
The plastic coolant resevoir on our 2005 MC only has about 1/2 inch in it. .......
This is very normal for our cars as far as I know. It's usually low enough that you can see baffles at the bottom of the tank.
Old Jun 26, 2005 | 07:17 PM
kenchan's Avatar
kenchan
I've added a dab of 50/50 mix a few times within 17.5k miles.
I check while the engine is complete cold and add just enough to
level off at the middle of the min/max marks. ive added coolant
to other cars that I have so i think it's normal.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Cruzer214
Oct 11, 2015 07:45 AM
navybsn
Oct 4, 2015 03:27 PM
Oct 1, 2015 12:13 PM
Emnotek
Sep 29, 2015 07:37 AM
