Rubbing Sound when turning at parking lot speeds
Old May 27, 2005 | 07:30 AM
mudflap's Avatar
mudflap
the right front of the car makes a rubbing sound, only when turning slowly (say in a parking lot or in and out of a parking space). at speed above 10-15 mph, it does not happen. the dealership told me it was my tires (as they were worn down), however after replacing them, the sound is still there. i searched the threads and didn't really see one that matched my description--anyone else have this issue?
Old May 27, 2005 | 08:48 AM
VoiD's Avatar
VoiD
I have the same problem after putting new tire/wheels.
there is no way the tire could rub anything as the car is on stock height and there's plenty of space everywhere.
let me know if you find out anything. I couldn't figure it out..
Maybe it's the power steering noise? but don't remember it being this bad.
Old May 27, 2005 | 09:01 AM
mudflap's Avatar
mudflap
my car is at sterling mini now (blew a tire and cracked a rim on a pothole last night ), they are going to take a look at the sound again after next tuesday (after the new tire arrives)--i'll let you know.
Old Jul 7, 2005 | 08:31 AM
aquaanox's Avatar
aquaanox
i have the same problem after putting new tires and wheels on. Did you ever figure out what the problem was ? thanks.
Old Jul 7, 2005 | 08:32 AM
mudflap's Avatar
mudflap
i had a cracked strut mount (right front)...they replaced it free of charge under warranty. the sound was prevalant before i hit the pothole...
Old Jul 7, 2005 | 08:47 AM
VoiD's Avatar
VoiD
When I took mine in, they said it's just tire noise
I have stock tires now and the sound is still there, although a bit less noticeable. Mine only sounds when I'm making a hard right turn with throttle.
I've decieded to just live with it. If something breaks, they should fix it as I still have a lot left on the warranty
Old Jul 7, 2005 | 08:59 AM
andromcs's Avatar
andromcs
I experience a rubbing sound also and had posted about it in the past. In the previous thread, we thought it was the sound of the LSD. I too am just living with it and waiting to see if any damage occurs...if so, hopefully during the warranty period!
Old Jul 7, 2005 | 09:15 AM
mudflap's Avatar
mudflap
yeah, i don't like the 'it's just tire noise' excuse, especially when it comes to suspension...i've never owned a car that made rubbing/screeching sounds when turning, but i have had tire noise with high performance summer tires, which was expected. i'd definitely push the issue. it the sound wasn't there when it was brand new, it shouldn't be there now.
Old Jul 7, 2005 | 09:25 AM
doomsdaybob's Avatar
doomsdaybob
I had it, cracked strut mounts. Both replaced under warranty. MINI knows they have a problem w/ original units but not advertising the fact. My SA treated it like no big deal. There is a separate thread here somewhere w/ pics of broken units and new replacement units.
Old Jul 7, 2005 | 10:47 AM
VoiD's Avatar
VoiD
Right. I would have considered it "tire noise" if it was consistent. I guess they just thought tire noise was what I was hearing and didn't bother test driving the car more. I was going to take the SA for a ride but he had already left when I went back to pick up the car. I'm just tired having to drive the dealer rental car.. (I had taurus, then a neon) I will bring up the issue again when the car goes in for its first maintenance schedule.
Old Jul 7, 2005 | 02:30 PM
planeguy's Avatar
planeguy
Does anyone have a picture of a cracked strut mount? Where does the crack develop? where can we check this. Sounds serious.
Old Jul 7, 2005 | 02:32 PM
VoiD's Avatar
VoiD
Here's a picture I found.
https://www.northamericanmotoring.co...sort=1&cat=500
Old Jul 7, 2005 | 03:03 PM
mbabischkin's Avatar
mbabischkin
Our car is headed in tomorrow for re-doing everything they were supposed to have down a week and a half ago (intermittant buzzing in the passenger speaker, stiff passenger seat, and the noise reported above...) We'll request that they inspect the strut mounts and see what they tell us...
Old Jul 8, 2005 | 11:15 AM
mudflap's Avatar
mudflap
definitely let them listen to the sound while you are in the car with the SA and with the hood open...the techs on two other occasions said they could either detect no noise or said it was due to balding tires...
Old Jul 8, 2005 | 11:31 AM
tommyb's Avatar
tommyb
I had the rubbing noise as well, busted front tie rodhere, fixed under warranty, but that did not produce the rubbing sound, my car guy said that there is a backer plate next to the rotors and they get rust on them which produces the rubbing sound, he put the car up on a lift and proceeded to turn the wheels and grind off the rust until the noise went away, it's back again but I think I should be able to do the job myself this time around,
tommyb
Old Jul 8, 2005 | 11:39 AM
CSAMF's Avatar
CSAMF
For a year now
The noise I hear sounds like the noise you get from a very old shock absorber, almost a creaking noise. Is that what everyone is hearing? I've had the noise from day one and it's been a year now. Maybe something isn't lubed enough is my first thought. I thought for sure if there was something seriously wrong with it, it would have been obvious or worsen during MOTD. Nothing. Still the same, no worse. Things that make you go "hummm".
Old Jul 8, 2005 | 12:44 PM
BearX220's Avatar
BearX220
I get a steady "whoop-whoop-whoop" rubbing sound from the right front of the car when turning left at low speed. Not a creaking noise, a friction-y noise. It sounds like tire rub, but it's not tire rub -- I have plenty of clearance. While my runflats have 23k on them and are somewhat worn, I can't believe this is the fault of worn tires -- they'd have to be ovoid or asymmetrical to cause this noise.
I'm going in for my 25k check in a week or two, and checking the strut mounts and tie rods is high on the to-do list.
Old Jul 8, 2005 | 12:47 PM
VoiD's Avatar
VoiD
that's what I hear. whoo whoo whoo then quiet then repeat with occassional creaking sounds mixed in with my 2000mile falken azenis..
less noticeable on OEM run flats(~1000miles) but the sound is still there when making hard right turns going up the underground garage ramp..
Old Jul 8, 2005 | 05:00 PM
YYC's Avatar
YYC
Had the same sound from the moment I picked up my '05 MCS in April. Repaired right away - pitted wheel bearing, probably defective at manufacture. No problems since.
When you turn left, you load the right side...pretty classic for a wheel bearing problem, I think.
Old Jul 8, 2005 | 05:52 PM
BearX220's Avatar
BearX220
YYC, thanks for the lead. That sounds very likely to be the culprit. Appreciate your help.
Old Apr 10, 2007 | 09:13 AM
Porco Rosso's Avatar
Porco Rosso
I had this same problem - occasional creaking sound on slow right turns - with my 06 MCSC, starting about 6 weeks ago. No major potholes or other suspension catastrophes, just regular driving. I do traverse about 6 speed bumps on an average daily commute, but I take them slowly and gingerly.
Anyway, had it fixed when I took her in for the 10k service. It was a cracked strut mount, replaced under warranty no questions asked. However, they implied that if the strut itself had also been damaged they would not have done a warranty repair.
Now I'm thinking maybe I should bug them to replace the other side with the newer/better strut mount before it too collapses and potentially causes more serious damage.
NYXF56JCW
Nov 17, 2024 05:06 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Powershift
Aug 16, 2015 05:14 PM
ASRman
Aug 13, 2015 09:33 AM
