Drivetrain Bosch Injectors
Old May 17, 2005 | 07:46 AM
XTREEM's Avatar
XTREEM
Bosch Injectors
Does anybody know the part number for the Bosch 380cc injectors? (that are a direct fit) I know Helix sell them but I am trying to source them in Australia and need a part number.
Thanks John.
Old May 17, 2005 | 11:45 AM
mattharris75's Avatar
mattharris75
Are these the TT225 injectors?
Old May 18, 2005 | 05:17 PM
XTREEM's Avatar
XTREEM
Not sure!!! Where did you get that number???
Has anybody here had their standard injectors uprated to 380"s or 400"s.
Old May 18, 2005 | 06:47 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I think he means injectors for a 225 hp Audi TT. They are 380cc as well and are used in some 1.8T turbo kits.
FWIW, I do not believe that the TT225 injectors are a direct fit.
Old May 18, 2005 | 07:10 PM
spillman's Avatar
spillman
They are not a direct fit. I have spoke with Eric about them and he says they must go through a machining process which he has done by a local shop.
Old May 18, 2005 | 08:11 PM
mattharris75
If these are the injectors that you are talking about, then I can get the part number easily enough. Don't know what sort of 'machining' they require for the MCS (The majority of the body being plastic, with only the tip being a thin medal body) But unless you have machining capabilites, then i'm not sure what good it's going to do you. :smile:
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
