Rubbing sound coming from the front end
Old May 4, 2005 | 05:51 AM
tommyb's Avatar
tommyb
I've just noticed a rudding sound coming from the front end of my MINI, it sound like my brakes are constantly on at low speeds. Does this sound serious or can I wait to get it to the dealer so they can look at it. I'm not the greatest at these types of things so I thought I'd ask here.
tommyb
Old May 4, 2005 | 05:56 AM
YYC's Avatar
YYC
Need more info....
What year is your Mini? Mileage?
Constant or variable sound?
Clicking? Thumping? Constant rub?
In time with wheel rotation?
Worse on cornering?
Present with clutch in or out?
Present at higher speeds?
Any changes in wheels/tires?
Old May 4, 2005 | 05:59 AM
RenaultF1's Avatar
RenaultF1
Yes, need more info. Also, is it a MCS and does it have LSD?
Old May 4, 2005 | 06:04 AM
tommyb's Avatar
tommyb
I have a 2004 MCS with about 18,000 miles on it, the sound seems to be variable durning tire rotation and does not get worse when I corner, it sems to be more of a rubbing sound then a clunk or thumping sound,
Old May 4, 2005 | 06:12 AM
ahamos's Avatar
ahamos
Coordinator :: River City Minis
Three things to have your dealer check:
1. CV joints
2. wheel bearings
3. caliper (could be frozen)
Old May 4, 2005 | 06:13 AM
tommyb's Avatar
tommyb
Do you think it's safe to drive until I can get it to the dealer?
Old May 4, 2005 | 07:29 AM
ahamos's Avatar
ahamos
Probably, if you don't do too much tooling around between now and then. I definitely would advise against driving to the Dragon with a mysterious and un-diagnosed rubbing noise.
Old May 10, 2005 | 06:36 AM
tommyb's Avatar
tommyb
Just found out what the rubbing sound was, a broken left front tie rod, only 18,000 miles and it breaks, what a bummer, luckily it's covered under warranty and now I get to drive around in a new BMW 325xi loaner car till they get it fixed, I guess I can drive it for a couple of days, its not a MINI but it sure is nice,
tommyb
Old May 10, 2005 | 07:04 AM
YYC's Avatar
YYC
Tie-rod failure described in a 2002 post, but likely a problem from the factory (new vehicle).
https://www.northamericanmotoring.co...ead.php?t=1021
Did you hit anything (e.g. curb) that could account for the broken tie rod?
Old May 10, 2005 | 06:38 PM
tommyb's Avatar
tommyb
You know Minnesota is the pot hole capital because of our winters here, I tried missing as many as I could but I don't remember hitting any that would cause that type of damage, the left front wheel was pretty lose, all I can say is I'm glad I wasn't going down a highway if it ever came loose,
tommyb
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
FatherG
11
Aug 7, 2015 07:49 PM
