Help me out with this dang driver side strut assembly.
Old Apr 29, 2005 | 06:42 AM
Kyle's Avatar
Kyle
How the heck do you compress the strut assembly enough to get it out? Yesterday I had the car up and jacked up underneath the A arm to compress the assembly, threw my spring compressors on the already compressed spring and tightened them down as much as they would go (ie, the two clamps on the compressor were touching each other and couldn't be threaded any tighter). When I let the suspension down again the bottom of the strut still had a good half inch before it would come out of the spindle. Do I just need better spring compressors or what? I've got the Harbor Freight cheapo special so maybe they don't compress as much as they should. I'd heard of some people using tie down straps to hold the spring, but that turned into a logistical nightmare when I tried to wrap those around the spring.
Any help would be great. I'm about to just go out and buy a lot of thick zip-ties and call it a day.
Old Apr 29, 2005 | 07:58 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Shorten the tie down strap until it is about 3 feet long. Hook the "s" hook ends to the top of the spring cover plate. Compress the spring with a floor jack. Tighten the strap that is looped around the bottom spring base. Remove strut. Install spring compressor on spring, remove strap and then undo the compressor. Hope that helps, I have done many Mini's like that.
Old Apr 30, 2005 | 02:51 AM
minniedryver's Avatar
minniedryver
no spring compressor used...
when I did mine last week. I disconnected the tie-rod, which gave just enough extra movement to free the driver's side assembly.
Old Jul 4, 2005 | 02:35 PM
sideburns's Avatar
sideburns
If you have a Bentley manual it tells you to disconnect the tie rod and control arm. I did this and the strut falls right out. I used a block of wood and a ten pound sledge hammer to release pressed on ball joint. Keep on hitting and it finally drops - no damage is done. Good luck
Old Jul 4, 2005 | 05:41 PM
002's Avatar
002
You can avoid the need for a ball joint remover by removing the control arm to strut ball joint by the two bolts at the bottom of the strut. Use something to pry the ball joint assembly from the strut an you should get all the clearance you need without popping any ball joints. I don't think you need to disconnect the tie rod. You can jack the hub up at the rotor to compress the spring while you release the control arm and ball joint.
Old Jul 4, 2005 | 06:21 PM
kenchan's Avatar
kenchan
I just loosened everything, turned the rotor ccw and the strut came out.
No need for spring compressors while on the car.
Old Jul 4, 2005 | 09:09 PM
k-huevo's Avatar
k-huevo
I use two endless loop ratcheting tie downs for getting the driver’s side out and a cedar plank wedged on a jack to get it in. I once used a two by four with the rotor as a fulcrum; I don’t recommend that procedure. At some point in the 03-model year the driver’s side got easier for whatever reason.
Old Jul 4, 2005 | 09:55 PM
CooperSS's Avatar
CooperSS
k-huevo,
That is correct, I helped a buddy with an early 03 and the drivers side was a problem until we undid the two bolts mentioned by 002. When we did my 04 the both sides just dropped out with no spring compressors or anything.
Bill
maestro39
Oct 27, 2015 02:38 PM
RACEnSK8
Aug 31, 2015 01:08 PM
StuRat
Aug 25, 2015 05:27 AM
one73ronin
Aug 19, 2015 12:36 PM
messyjesse96
Aug 12, 2015 05:51 AM
