Navigation & Audio XM Roady Antenna Wire - Get unlocked door warning.
Old Mar 11, 2005 | 10:53 AM
kraigster414's Avatar
kraigster414
I have XM radio now (Roady). The problem with the Roady is the antenna wire. I have the wire going out the hatch back, antenna mounted on the rear of the roof. I keep getting a warning signal that my hatchback door is not closed securely - wow the sensor must be sensitive because the hatchback door closes just fine. Anyway to get around this? I have threaded the antenna wire every which way. I guess the Sirius plug and play unit will cause the same problem, right?
Thanks!
Old Mar 11, 2005 | 11:17 AM
Johnna's Avatar
Johnna
Thanks!
I've got a Roady antenna wire that goes out the back hatch and I have had no problem at all with the "hatch open" warning light.
I pulled down the hatch gasket, pulled the antenna through and put the gasket back in place.
Maybe there is something else going on???
Old Mar 11, 2005 | 11:53 AM
kraigster414
Nah, it somehow sensed the antenna wire and concluded the hatch was not closed properly. But the problem was on my old Mini. I now have a new Mini and have not tried it yet. Hope it works.
Old Mar 11, 2005 | 12:53 PM
flav's Avatar
flav
same here, but i get no warning light either.
Dec 23, 2015 10:36 AM
polotska
Aug 23, 2015 03:03 PM
Super Coop
Aug 17, 2015 05:09 PM
