Navigation & Audio Aux input Jack-problem
Old Mar 8, 2005 | 08:39 AM
LeftyS7's Avatar
LeftyS7
I installed an euro shelf with a second power outlet and aux input jack The power doesn't work (I'm not too concerned about that, I can trace the power and check to see if I have a proper ground). But, running an IPod from the factory power outlet, the aux input does not seem to work. I have the stereo set for aux and have changed the aux volume settings and...nothing.
Am I overlooking something obvious? If not, how do I trouble shoot this? I couldn't see the back of the stereo when I plugged in the aux input cord plug but it seemed to fit, easily, and, given its unusual shape I can't believe I made a wrong connection.
Any ideas? Thanks
Old Mar 8, 2005 | 11:19 AM
AldoS's Avatar
AldoS
Is your car an '02 build? If so,the aux port is on the head unit but it's not functional.
Old Mar 8, 2005 | 11:32 AM
mbabischkin's Avatar
mbabischkin
It shouldn't even recognized the Aux input then. You can't select it on the HU if you try on an 02 HU
Old Mar 8, 2005 | 01:02 PM
aminicooper's Avatar
aminicooper
try cranking the ipod volume up, then crank the radio's volume... if that still doesn't work, maybe you didn't connect it correctly/ all the way inserted?
Old Mar 8, 2005 | 04:12 PM
LeftyS7's Avatar
LeftyS7
Mine's an '05, I'll try the volume suggestions. Then I'll try to reconnect it (not like there are a lot of places to go wrong). Thanks.
Old Mar 8, 2005 | 05:31 PM
Todd05HBS's Avatar
Todd05HBS
The AUX cord could be bad. A few months ago, I met up with someone having the same problem. We tried my cord (both fresh out of the bag) an it worked. Just a bad cord. Hope this helps and Good Luck!
Old Mar 9, 2005 | 07:51 PM
LeftyS7's Avatar
LeftyS7
Switched cables and still nothing.
I thought that perhaps I'd plugged the plug end into the wrong socket at the back of the radio, so I crawled under the dash and couldn't see the back of the radio with the Euroshelf in place. What I could see was the back of the aux input jack - and the male plug sticking through! The cable that is connected to the jack had pulled off when I zip-tied it to a steering column brace! Pushed it back on, after feeding a little more cable through the zip-tie to give it some slack, and, Presto! Sound through the aux mode!
rikaro
Nov 24, 2015 02:05 PM
eliseo1981
Nov 2, 2015 11:24 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
