Interior/Exterior Give me a brake
Give me a brake
I visited Peter of MyMini and purchased a simple little wiring kit w/ EXCELLENT
how to instructions which enables the use of the upper rear fog lights in the rear tail lights when you brake. Took 15 minutes and WOW
does the back light up when you hit the brakes.
Worth the big $12 expenditure. Top notch instructions - thank you Peter.
does the back light up when you hit the brakes. Worth the big $12 expenditure. Top notch instructions - thank you Peter.
[QUOTE=Bahamabart]I visited Peter of MyMini and purchased a simple little wiring kit w/ EXCELLENT
Worth the big $12 expenditure. Top notch instructions - thank you Peter.[/QUOTE
personally I think Peter should be SPANKED for selling you a $12 "kit".
Do a search For "brake light mod" Zero $ Only takes about 1 min. If you have the rear fog lights that come on with the fronts, then all you would need are 2 inexpensive diodes to use instead of wire or paperclips. One of my favorite modds + its "FREE" The newer tail lights with back-up light probably still have the same color coding.
does the back light up when you hit the brakes. Worth the big $12 expenditure. Top notch instructions - thank you Peter.[/QUOTE
Sorry the site is - www.myminiparts.com
This enhancement is not rocket science and if one has the time to run around to research, purchase diodes, wires and connectors then you can save yourself the $12.
BUT for me it was well worth it from a time perspective :smile: -
1) Good instructions with color pictures - step by step - no doubts along the way.
2) diodes incorporated into the wires and shrink wrapped 3) self tapping connectors (just squeeze with pliers).
4) ends marked to get the diode going in the right direction.
By the time you calculate the radio shack items plus fabrication at min. wage - I bet you are over this wopping $12 investment.
Time IS Money!
Time IS Money!
I did the mod for $1.51 after tax. I guess I was lucky to already have pliers, electrical tape, and a gel-pen...
I would, however, have paid $12 if there had been an intermediate connector between the tail-light ***'y and the actual car wiring. Jamming diodes into the back-sides of sockets doesn't make me as happy as fabricated parts. Somehow I always fear a fire, even though I do trust my skills for such a simple task.
Man, is this a great mod, or what? I really think this is an important one, too, as SUV's get larger and larger, and I feel like my little "postage-stamp on the road" needs as much safety as she can get.
Thats just it
The diodes were incorprated into the wires and then covered with plastic heat shrink. Both ends had self taping wire ends that you simply squeezed with pliers - SO I thought it was wel worth the $.
I very much agree with you that it is a must have - anything that keeps a hummer out if my exhaust pipes is a good thing.
I just installed the brake light kit from myminiparts.com, WOW! The wiring could not have been easier, they even included a circuit tester! The cheesy plastic plug popped right out and the neww lamp snapped in place. The directions were top notch. I'd recommend this mod to everyone!
Steve A.
Ballard WA
Steve A.
Ballard WA
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
cornfly888
Aug 24, 2015 09:57 AM
