R50/53 Clutch pedal was on the floor, couldn't get out of gear
Old May 4, 2026 | 11:12 AM
BMH94's Avatar
BMH94
Just as the title states. I couldn't get out of gear. Noticed clutch pedal was on the floor. Turned the car off. Brought the clutch pedal back up with my hand. After that, it was fine for a little bit. I looked at the clutch master and slave cylinder. No external leaks from either one of them. Clutch pedal is dry. No clutch slipping. Or unusual sounds. What should I do from here?
2003 r53
Old May 4, 2026 | 02:50 PM
ssoliman's Avatar
ssoliman
this sounds like an issue with the hydrolics somewhere. is your fluid up to level in the reservoir?
Old May 4, 2026 | 02:57 PM
BMH94's Avatar
BMH94
Yes, fluid level is at max level. Never had to add any in the past, either.
Here2Go's Avatar
Here2Go
NAM Community Team
A novice guess -
Check your hydraulic reservoir by running your had around the top backside (underneath the cowl). You may find that the plastic reservoir has degraded and not retaining pressure.
These things are made of cheap plastic and common to failure.
Old May 4, 2026 | 03:13 PM
ssoliman's Avatar
ssoliman
the res should not be under pressure
how old is your clutch kit?
Old May 4, 2026 | 05:40 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Ah. I was thinking perhaps low fluid level + cracked reservoir allowing air into the system.
Old May 4, 2026 | 05:42 PM
BMH94's Avatar
BMH94
Car has 72k miles. Clutch was replaced at 30k miles. I run this car hard. Never notice anything up with the clutch.
Old May 4, 2026 | 09:44 PM
LukasH's Avatar
LukasH
It could be that an internal seal is blown in the master/slave cylinder, resulting in no external leaks but no pressure on the pedal. Until you fill that void with fluid again.
Although I'm pretty your clutch shouldn't be working after that. Interesting case.
Old May 5, 2026 | 12:11 PM
BMH94's Avatar
BMH94
Clutch slave cylinder is dry inside. Move onto something else?
Old May 5, 2026 | 02:55 PM
BMH94's Avatar
BMH94
not sure if this helps. But a visual inspection of the clutch master cylinder.
Old May 5, 2026 | 03:22 PM
ssoliman's Avatar
ssoliman
ok so newer clutch. very interesting case / mystery
how old is the slave and master?
if the system operational right now?
Old May 5, 2026 | 03:24 PM
ssoliman's Avatar
ssoliman
this system only has pressure in one direction. towards the slave and towards the brake calipers. air can enter the system if the res runs dry
Old May 5, 2026 | 05:32 PM
BMH94's Avatar
BMH94
Based on the service history, master and slave were replaced at the same time as the clutch. 30k miles, back in 2018.
Yes, I drove it like a mile and it was fine. It does it very sporadically.
Old May 5, 2026 | 05:38 PM
BMH94's Avatar
BMH94
Also, the brake master reservoir is full. I've never had to fill it.
Old May 6, 2026 | 02:42 PM
ssoliman's Avatar
ssoliman
there is at least one spring that pushes the clutch pedal back up. one on the clutch pressure plate and maybe on on the clutch pedal. now i cant remember if these cars have one on the clutch pedal?
Old May 6, 2026 | 03:22 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I think @ssoliman had an interesting thought about a spring.
I already had my knee bolster down so I took an opportunity to snap a pic or 2wo...Possible spring connected to the clutch pedal...
Old May 6, 2026 | 05:58 PM
BMH94's Avatar
BMH94
Interesting! I'll take a look, thanks guys.
Jtguethe
Dec 18, 2025 01:04 PM
JoeM56
Nov 5, 2017 06:11 AM
TheDude
Sep 17, 2013 05:38 AM
darigaaz12
Sep 20, 2007 08:50 PM
wikedgolf
Jun 4, 2007 04:04 PM
