R56 R56 - crossover pipe/thermostat - now running rough
Old Apr 18, 2026 | 06:52 PM
Dunl's Avatar
Dunl
Hi all,
I did the crossover/thermostat job, and besides overheating when it failed, the vehicle was running fine. Once reassembled, it now is throwing codes for each cylinder. I cleaned out the plugs, made sure everything was plugged in correctly....in fact, I removed and reinstalled everything right down to the intake manifold.
Symptoms are that it runs rough, accelerator will make the rpms rev really high once and then it dies off. Cannot maintain idle, stops with any fuel given.
Any suggestions?
Thanks in advance.
Old Apr 18, 2026 | 08:04 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Misfire codes? Post them.
Old Apr 18, 2026 | 08:34 PM
Dunl's Avatar
Dunl
I don't have the fanciest code reader, but:
P0300
P0301
P0302
P0303
P0304
P0137
and also the above 6 codes repeated with a "pd" following each one.
Old Apr 19, 2026 | 03:25 AM
Maybe, maybe not
Community Builder
What year R56? N12, N14, N16, or N18?
How badly did the engine overheat?
For downstream O2 sensor code P0137, check whether the connector may be contaminated with coolant or whether you potentially swapped the O2 sensor connector with another sensor connector.
Old Apr 19, 2026 | 05:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If you had the intake manifold off, I’d be tempted to think you have an intake leak or something didn’t get reinstalled correctly
Old Apr 19, 2026 | 08:21 AM
Dunl's Avatar
Dunl
It's a 2008 n12 non-turbo. I pulled off and headed towed when it started to overheat, so not too badly.
My thoughts yesterday as well were that maybe I swapped a couple of sensors, but I'm not sure which sensors would actually be able to be interchangeable?
I'll check the o2 sensor connector, thanks
Old Apr 19, 2026 | 09:35 AM
Raymo2u's Avatar
Raymo2u
I would double check the vacuum lines and hoses under and around the intake, then check the plugs around the thermostat
Old Apr 19, 2026 | 09:52 AM
Maybe, maybe not
Community Builder
Good question. I can't think of a nearby 4-pin connector that can be swapped with the downstream O2 sensor connector. Just for verification, check whether the wire colors match the wire diagram (orange, white, yellow, black).
Old Apr 19, 2026 | 01:23 PM
Dunl's Avatar
Dunl
I'm stumped. Everything seems to be connected correctly.
Old Apr 19, 2026 | 01:31 PM
Maybe, maybe not
Community Builder
As mentioned by others, a vacuum or intake air leak is where to focus now. Given your removal of the intake manifold, look into doing a smoke test. The brake booster and PVC pipe are other prime suspects.
Did the O2 sensor code appear before or after the recent work?
Old Apr 19, 2026 | 04:29 PM
Dunl's Avatar
Dunl
It appeared after the recent work. I don't have a smoke machine, will have to source one.
Old Apr 19, 2026 | 04:53 PM
Maybe, maybe not
Community Builder
A massive vacuum or intake leak can cause both P0137 and misfires by causing extremely lean conditions.
P0137 seems to confirm an air leak. Did you install a new intake manifold gasket?
Old Apr 19, 2026 | 08:08 PM
Dunl's Avatar
Dunl
I did not. I suppose it wouldn't hurt to try.
Three complete removals/installs now. Without rushing at all pretty sure I can do it in twenty minutes now.
evilways570
Feb 8, 2023 05:28 AM
JackM56
Mar 3, 2020 06:32 AM
guruerror
Dec 13, 2019 04:53 AM
gnarmach
Sep 4, 2019 06:28 PM
S-2013
Mar 30, 2019 07:04 AM
