R56 Need help with locating oil leak
Old Mar 26, 2026 | 06:25 PM
white46's Avatar
white46
So a few months ago, I replaced turbo oil feed/return lines and oil filter housing gaskets, and recently I've been smelling oil burning smell again.
I thought it's the turbo oil feed line again, so I opened it up again, but surprisingly the line is fine.
Based on the photos, does it look like oil is leaking from valve cover gasket??
Clean oil feed line and oil filter housing.
Oil residue on exhaust mani cover.
Bolts are baked with oil.
Heatshield that is between cat and turbo oil feed line.  Notice the oil residues are on the top of the cover, which mates to exhaust manifold cover.
Old Mar 31, 2026 | 03:44 AM
mkov608's Avatar
mkov608
I've used this several times to help identify the source of oil leaks.
Amazon Amazon
Old Mar 31, 2026 | 08:06 AM
Valve cover gasket is my guess. But i dont see the top gasket leaking. Might be a pinhole leak on a line or a bad copper washer. I would clean it out and check again after a heat cycle.
jzhou0222
Apr 29, 2025 07:01 AM
Minimedic501
Jan 24, 2017 04:39 AM
vincedprince
Dec 29, 2016 06:45 AM
jbourne
Sep 12, 2016 12:17 PM
Semaphore
Feb 11, 2015 10:23 PM
