R52 Probleme CVT
Old Mar 24, 2026 | 11:57 AM
Dom7362's Avatar
Dom7362
Probleme CVT
Title: Automatic transmission problem – 2008 Mini R32 (R56) with fault codes 1786, 1787, 1698
Body:
Hi everyone,
I'm having issues with the automatic transmission on my 2008 Mini Cooper (R56). The car seems to be shifting poorly, and I ran a diagnostic scan which revealed the following fault codes in the DME (ECM2):
  • 1786 – DME: Transmission ratio actuator – range of performance problem
  • 1787 – DME: Transmission ratio actuator – open circuit
  • 1698 – DME: Transmission control module – activation fault
Also, in the Kombi (instrument cluster), I have a fault indicating a problem with the electronic control unit.
Battery voltage was around 14.13V at the time of the scan, so that seems okay.
What I have already done:
  • Replaced the speed sensor
  • Replaced the idle air control valve position sensor (stepper motor drain position)
  • Tested with another CVT transmission control unit (ECU)
Unfortunately, the issue is still present.
Has anyone dealt with these codes before? Could this be a faulty transmission actuator, a wiring issue, or something else? Any advice on where to start troubleshooting would be greatly appreciated.
Thank you in advance for your help, and sorry for any inconvenience.
Best regards,
mini845
Jan 13, 2026 01:51 PM
dcwang3
Nov 5, 2022 07:19 AM
jwh
Jun 29, 2022 12:22 PM
bond_007
Oct 20, 2020 06:32 PM
rednet
May 13, 2011 03:07 PM
