R56 2008 cooper S crank no start
Old Feb 22, 2026 | 02:24 PM
Setflyn41's Avatar
Setflyn41
I recently bought a 2008 mini cooper s with the n14 engine with 67000 miles it was a crank so start when I bought it. Previous owner said they replaced hpfp, lpfp, fuel filter, and the timing chain.
the hpfp was a cheap knockoff
i got a used hpfp oem to try but same results
ista shows actual fuel rail pressure as 0.38-0.40 this never really changes.
i have checked that fuel is getting to the hpfp and that the camshaft is spinning.
i have tested the plug and get proper power and signal
I smoke tested the gas tank and didn’t find any leaks
any advice on what to do from here it will start on starting fluid
Old Feb 22, 2026 | 05:37 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
What pressure units does ISTA use for rail pressure? Is it MPa?
Are you sure you are reading rail pressure rather than the low pressure system with ISTA?
Old Feb 23, 2026 | 01:34 AM
Setflyn41's Avatar
Setflyn41
Yes mpa, i haven’t found a way to measure the low pressure system with ista. I know fuel is coming into the high pressure pump but isn’t coming out of it to the fuel rail
Old Feb 23, 2026 | 04:00 AM
Maybe, maybe not
Community Builder
When you crank the engine, does the tachometer register the engine rpms?
Old Feb 23, 2026 | 04:58 AM
Setflyn41's Avatar
Setflyn41
I’ll have to check that’s a good suggestion I didn’t look at that
Old Feb 23, 2026 | 05:29 AM
Maybe, maybe not
Community Builder
You may be able to diagnose the fuel issue using ISTA.
In ISTA “Diagnosis request/measured values”, compare the four items below with "Key ON, Engine OFF-not cranking" versus "Cranking for 8–12 seconds":
1) Rail pressure (Actual) [expert list parameter #407] - your previous reading of 0.38-0.4 MPa
2) Rail pressure: Setpoint value (Target) [expert list parameter #408] - should be ~5MPa
3) Quantity control valve/activation signal (HPFP metering valve command) [expert list parameter #411]
4) Engine speed (RPM) [expert list parameter #101]
Old Feb 26, 2026 | 02:09 PM
Setflyn41's Avatar
Setflyn41
1) 0.38mpa
2) 5.00mpa
3) checks out
4) showing rpm’s around 1-200
Old Feb 26, 2026 | 02:40 PM
Maybe, maybe not
Community Builder
The cranking rpms are a bit low, but your results indicate that:
1) The camshaft is NOT driving the HPFP to generate high pressure. Potential causes: HPFP not seated correctly in its mounting position, pump drive tang (B) not properly seated into cam groove (see image below), or internal failure of HPFP.
or
2) The camshaft is driving the HPFP to generate high pressure but the pressure is being lost. Potential causes: rail relief/limiter stuck open, injector leaking, or internal HPFP failure.
Old Feb 27, 2026 | 06:52 AM
Maybe, maybe not
Community Builder
You also may want to check whether the high fuel pressure sensor is working. For example, unplug it and see whether the ISTA pressure reading changes. If so, try starting engine with pressure sensor unplugged.
Old Mar 1, 2026 | 05:11 PM
Setflyn41's Avatar
Setflyn41
Just in case anyone runs across this, after installing a mechanical fuel pressure gauge it showed 0 psi, pulled the low pressure fuel pump and the fuel filter as well to find the o-ring for the filter lid had come off. No clue why ista showed rail pressure but don’t trust it and use a mechanical gauge.
starts fine now
hobhancock
Dec 15, 2024 06:36 PM
Droidzilla
Nov 6, 2023 06:21 AM
Brian715
Jan 31, 2021 03:18 PM
Rudy717
Oct 30, 2019 03:59 AM
fuzejonez
Nov 7, 2013 08:29 AM
