R50/53 R50 ignition switch, starter or wiring? no code
Old Feb 5, 2026 | 03:31 PM
fnkyhd's Avatar
fnkyhd
hey all! my 03 R50 starts intermittently but when it won't it won't and no code. no problem with accessories or dash and headlights, all getting power. i was getting it to start with a jump so i put the voltmeter on the battery and it was a bit low at 12.5. also checked with it running and had a good 14.5 reading so i replaced the battery with an optima red top (the car sits a lot). still having intermittent start issues. i thought it was fine and drove to the store but it wouldn't start up again after shopping after about ten tries. with some help i bump started it and drove it home. when i got home and shut it off it started right back up again. i recently did a head gasket, valve job and some other stuff so things got jostled around but not finding and bad wires. the car runs amazing/like new after the work i did but only when i can start it. any thoughts?
Old Feb 5, 2026 | 07:25 PM
noodlesandsam's Avatar
noodlesandsam
Check ground connections -
Old Feb 6, 2026 | 03:44 PM
fnkyhd's Avatar
fnkyhd
thanks! i took a closer look and found the ground strap on the passenger side by the motor mount loose. easy peasy!
TheLoringLank
Jan 4, 2022 07:22 PM
Wes13coupe
Oct 24, 2020 05:15 PM
atomic5150
Aug 13, 2014 05:41 PM
tgfh
Cooper (non S)
May 19, 2012 02:23 PM
1nf3rn0
Apr 20, 2008 07:49 PM
