R50/53 o2 Sensor Spacing
Old Jan 2, 2026 | 07:56 AM
Minor Threat's Avatar
Minor Threat
o2 Sensor Spacing
Does anyone struggle with broken o2 sensors on their R53? My rear sensor seems to not have enough space between the wires and the frame of the car, regularly breaking wires. I had this problem with the stock and now my Miltek exhaust. Has anyone found a solution to this? Does anyone else have this problem regularly? I have seen 90degree adapters but haven't tried one yet.
Old Jan 2, 2026 | 11:17 AM
ssoliman's Avatar
ssoliman
i've not heard of this being an issue. have a pic?
Old Jan 3, 2026 | 08:48 AM
MikeW2's Avatar
MikeW2
I have the same issue with my new Magnaflow (from Hottexhaust) converter on my r50. Will try banging on the heatshield to make some room for the cables.
Old Jan 3, 2026 | 10:25 AM
MikeW2's Avatar
MikeW2
Old Jan 3, 2026 | 10:35 AM
MikeW2's Avatar
MikeW2
After banging on the shield. Enough for a small gap from the cables.
Old Jan 5, 2026 | 07:13 AM
ssoliman's Avatar
ssoliman
yeah that is close. maybe you can bend the shield a bit more. and maybe wrap it with heat tape, heat shield wrap to protect the wires
Old Jan 5, 2026 | 02:52 PM
ghostwrench's Avatar
ghostwrench
I have the Milltek header and exhaust. I have my cat oriented so that my O2 is toward the driver side, so no interaction with the heat shield at all. Not sure if that’s right or not but I thought I saw something that stated Milltek label faces down?
I know generally, O2 sensors are supposed to be on the upper half of the pipe so I found it odd to put mine like this but I decided to go with it. No problems so far after about 3 months and a little over 1000 miles.
AndrewVanis
Dec 1, 2021 09:11 PM
Gerard778
May 6, 2021 10:13 AM
greystone
Apr 1, 2014 05:58 AM
northbarts
Feb 24, 2013 12:31 PM
kmckmc
Dec 21, 2011 10:03 AM
