R60 How many miles on your R60 Countryman-What repairs have you done to it?
Old Dec 30, 2025 | 08:27 AM
ski.dive's Avatar
ski.dive
How 'many miles' on your R60 MINI Countryman?
What 'repairs' have you done to it?
Old Dec 31, 2025 | 03:46 AM
HausMD's Avatar
HausMD
Alliance Member
Veteran: Army
My Son’s 2014 R60 has 81k miles on it and the maintenance that’s been completed outside routine is having to have the oil filter housing replaced but now the rear main seal has developed a tiny leak that will be resolved soon. Other than that the valve cover gasket, timing chain and guides were replaced recently as preventative measures. Other than that, it’s dropped on HR Springs and the Powerstop brake rotor and pads kits were just done too. Purchased used with 44k miles on it then and previous owner took good care of it but originally was a Miami car and salt air content tend to wear rubber seals sooner as we’ve learned. Other than that he loves it an takes good care of it while he’s in college.
Old Jan 1, 2026 | 08:04 PM
Raymo2u's Avatar
Raymo2u
My 2016 CMS All4 S has 115K on it.
I have replaced the Battery, Thermostat, Alternator, Waterpump, PVC Diaphragm, are the only real things I "HAD" to fix outside of basic maintenance like Oil/Brakes, I have done much more for fun/looks. I do expect to do the Clutch and Flywheel this or next year. I love the car, its been very reliable is comparison to my R56.
Old Jan 2, 2026 | 03:51 PM
Neil Gaudet's Avatar
Neil Gaudet
Photo from Feb 2025
Photo from Feb 2025
My 2016 S has had very little done to it. Routine maintenance. Battery. Tires. Brakes. Oil changes etc. At some point early in its life it had a sensor replaced, but I don’t recall which one and it was under warranty. It’s been relatively trouble free for a 9.5 year old car. I bought it new and it has 163,000km on it.
Old Jan 2, 2026 | 03:54 PM
Raymo2u's Avatar
Raymo2u
Originally Posted by Neil Gaudet
Photo from Feb 2025
Photo from Feb 2025
if anything happens to the car, please sell me the side skirts and rear lip please!
Old Jan 3, 2026 | 06:15 AM
Neil Gaudet
At this point I kind of hope to drive it until it dies. It’s been my favourite car I’ve ever owned. So hopefully you wait a very long time.
Old Jan 7, 2026 | 04:24 PM
BlazingE60's Avatar
BlazingE60
I no longer own the 2014 Countryman S (FWD), but I have almost the complete service history to 120,000 miles. In order of replacement (note that first 100k it was in Miami, FL)
40k A/C Evaporator
40k Head Gasket & Exhaust VANOS
66k Main Battery
66k Thermostat
74k Rear Main Seal
76k Turbo oil line & oil filter housing gaskets
104k Thermostat & water pump to thermostat coolant pipe & Main battery
114k All 4 parking lamp / reflectors & coolant expansion tank (cracked nipple)
115k Ignition coil packs (1 failed) & both tailgate struts (weak)
117k Flush heater core for better performance
Old Jan 7, 2026 | 04:45 PM
HausMD's Avatar
HausMD
Alliance Member
Veteran: Army
40k A/C Evaporator
66k Main Battery
66k Thermostat
74k Rear Main Seal
Sheesh… head gasket at 40k? That’s wild!
Old Jan 8, 2026 | 03:32 PM
2014 MC's Avatar
2014 MC
Battery lasted longer than the head gasket?
Old Jan 9, 2026 | 03:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
“Head gasket” or “cam cover gasket”?
Old Jan 11, 2026 | 07:26 AM
Grumpy Goat's Avatar
Grumpy Goat
I am new to MINI ownership having bought my 2014 MINI Countryman Cooper S last December. Had just over 136k miles on it 😦 and was a decent price. Was very well cared for according to the CarFax Report and also the independent shop I took it to since taking delivery. Immediate maintenance requirement was the serpentine belt which was badly cracked, and which was replaced along with the accessory belt tensioner and belt idler friction wheel. There are other less urgent maintenance items to get done but overall, nothing unexpected for a car with this many miles on it. As a car from the southern US its body is in excellent shape (no rust). Compared to the aesthetics of some of the cars on this forum this one is plain, and I intend keeping it stock as I am not looking for a money pit. 😉
Old Jan 12, 2026 | 04:27 PM
BlazingE60's Avatar
BlazingE60
Head Gasket. Upon closer look at the first part, it's a full set of 16 valve stem seals. Maybe the "fix" was to reseal the head and the head gasket was just a consumable. Here is what the MINI Dealer replaced:
Repair kit valve seal ring
Part | 11 34 0 033 950
Gasket ring
Part | 07 11 9 963 201
Profile-gasket
Part | 11 61 7 528 340
Cylinder Head Gasket Asbestos-Free
Part | 11 12 7 595 138
Set Bolt Cylinder Head
Part | 11 12 7 560 274
Washer
Part | 11 12 7 550 856
Set of profile gaskets
Part | 11 12 7 582 400
Profile-gasket
Part | 11 51 8 613 803
Torx bolt
Part | 11 36 7 536 087
Gasket ring
Part | 11 31 7 550 461
Gasket ring
Part | 11 31 7 631 972
Flat gasket
Part | 18 30 7 589 503
Flange nut
Part | 18 30 7 583 746
Clamp
Part | 18 30 2 756 352
Gasket ring
Part | 07 11 9 963 151
Antifreeze
Part | 82 14 0 031 133
Set oil-filter element
Part | 11 42 7 622 446
BMW Group LL-01 FE 0W-30 Bulk Tank
Part | 83 21 2 450 384
42
Old Jan 13, 2026 | 12:46 PM
gallant.nick's Avatar
gallant.nick
I have a 2012 S All4 I picked up in 2022 for too much money due to used car options at the time locally, but the thing has been the most fun car I've ever driven... when I could drive it. I bought it with 180,000km (112k miles) and I used it for a lot of highway driving to start and then back to city and it's up to 234000km (140k miles).
In the beginning it needed all 4 wheel bearings, a fuel pump eventually and then the plugs and coils due to misfiring. I had to replace the evap sensor and then normal bumpy road items like ball joints, end links and tie rod ends. I've done brakes and refinished the wheels due to curb rash by the previous owner. I consider all this normal wear and tear.
Since then, it borked itself in 2024 when the clutch fork seemed to decide it prefered teh afterlife and snapped in half. It sat for more than a bit due to other priorities because I knew if I'm going in that deep for the clutch fork it was time to do some other maintenance too. So this November I started what was supposed to be a big but relatively quick project which spun out and I'm still working on it, in the snow but hoping to get the front end back on this weekend. But here's what's ended up on my list....
clutch fork
clutch and flywheel
slave cylinder
rear seal
front seal
timing chain kit
vanos sensors
new valve cover and gasket (mine was leaking)
oil pan
water pump
drive belt
then I broke the tensioner, so a new tensioner. Also noticed the alternator was seized and so was the AC compressor... so new ones of those and tosed in a new condensor as well.
the transmission fill plug wasn't coming out so I had to get nasty with it, so new one of those too... new axle nuts too. Also noticed I had a broken rear shock coil, so new set of those. New filters and fluids for every wet part of the car but that's all normal maintenance, just all done at once.
All in all, the extra stuff like the alternator and AC components failing while sitting worked out because they were much easier to service with the front end off but holy did not need those added to my list.
Also, when pulling the tranismission only out to get the fill plug sorted, putting the transmission back I broke the aux coolant pump for the turbo - so that was unexpected but relatively cheap and new one will be here Thursday in time for my weekend of putting this back together.
Old Jan 13, 2026 | 12:49 PM
ski.dive's Avatar
ski.dive
Originally Posted by gallant.nick
i have a 2012 s all4 i picked up in 2022 for too much money due to used car options at the time locally, but the thing has been the most fun car i've ever driven... When i could drive it. I bought it with 180,000km (112k miles) and i used it for a lot of highway driving to start and then back to city and it's up to 234000km (140k miles).
Since then, it borked itself in 2024 when the clutch fork seemed to decide it prefered teh afterlife and snapped in half. It sat for more than a bit due to other priorities because i knew if i'm going in that deep for the clutch fork it was time to do some other maintenance too. So this november i started what was supposed to be a big but relatively quick project which spun out and i'm still working on it, in the snow but hoping to get the front end back on this weekend. But here's what's ended up on my list....
Clutch fork
clutch and flywheel
slave cylinder
rear seal
front seal
timing chain kit
vanos sensors
oil pan
water pump
drive belt
then i broke the tensioner, so a new tensioner. Also noticed the alternator was seized and so was the ac compressor... So new ones of those and tosed in a new condensor as well.
The transmission fill plug wasn't coming out so i had to get nasty with it, so new one of those too... New axle nuts too. Also noticed i had a broken rear shock coil, so new set of those. New filters and fluids for every wet part of the car but that's all normal maintenance, just all done at once.
All in all, the extra stuff like the alternator and ac components failing while sitting worked out because they were much easier to service with the front end off but holy did not need those added to my list.
Also, when pulling the tranismission only out to get the fill plug sorted, putting the transmission back i broke the aux coolant pump for the turbo - so that was unexpected but relatively cheap and new one will be here thursday in time for my weekend of putting this back together.
good luck!!!!
Old Jan 13, 2026 | 12:50 PM
gallant.nick
Thanks so much! Appreciate it!! I got myself a fancy beer for when I was done and really thought I'd have drank it in November but here we are. So maybe by next weekend I can have it. I suspect I won't get to the rear shocks this weekend or replacing my flex pipe but it's getting so close!
Old Jan 13, 2026 | 02:41 PM
Grumpy Goat
Thanks for the amusing post. Seems like you are breaking stuff as you go along. 😊 Good luck for a clean break-free finish. Kudos to you for doing this outside in winter in the snow.
Old Jan 13, 2026 | 03:02 PM
gallant.nick
Haha thanks! And happy to provide some entertainment. I intend to compile my misadventures into its own post later on so have a beer on hand and ready for a riot of a read 😆.. I also owe RockAuto and ECS the story too.
Old Jan 13, 2026 | 06:27 PM
Raymo2u's Avatar
Raymo2u
I recently slid off the road the previous weekend and thank God for the amount of snow we had. The car slid up on top of a boulder...saving the car from being completely destroyed. I had to walk 2 miles in the freezing rain wearing just a hoodie which wasnt great when its 18°F back to my mother's house at midnight.
I lost a foglight, headlight washer covers broke off, torn apart the JCW lip, 5" hole in the windshield where a tree branch nearly impaled me, a-pillar cracked in half, front right inner fender torn out, and ripped off the wiring/plug for the AC.
After I had the windshield replaced this saturday, I was told my car was leaking oil. It looked like oil was pissing oil between where the turbo bolts to the manifold. My forge BOV wasnt making noise so I assumed that the turbo seals went. After spending 5 hours reolacing the turbo...it was still leaking. Looking more closely, the oil feed line was the cause, but there wasnt any clear reason - no pinch, no tear, no hotspot on the braided line...so I teplaced it as well...
I just got the car back together...about a grand lighter in the wallet...thank you winter.
Be careful out there guys....
Old Jan 14, 2026 | 03:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Oh man, what an event!
By the way, I don’t think the oil feed line should be routed over the manifold like that…
Old Jan 14, 2026 | 07:28 AM
ski.dive's Avatar
ski.dive
[QUOTE=Raymo2u;4706450]I recently slid off the road the previous weekend and thank God for the amount of snow we had. The car slid up on top of a boulder...saving the car from being completely destroyed. I had to walk 2 miles in the freezing rain wearing just a hoodie which wasnt great when its 18°F back to my mother's house at midnight.
I used to live in VERMONT lots of road salt, rusty cars everywhere.
Old Jan 14, 2026 | 07:30 AM
ski.dive's Avatar
ski.dive
Old Jan 14, 2026 | 08:42 AM
Raymo2u's Avatar
Raymo2u
Good catch, but isnt it over the right hand side of the manifold amd then hanging just under the manifold if routed the other direction? I have had it routed the same way on my R56 for about 3 years, but Ive never had this issue before.
I ordered a HEL heat wrap for the line, I will be rerouting it and adding the wrap.
UPDATE: Line rerouted
Old Jan 14, 2026 | 10:08 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes, follow the OEM oil line routing.
You might want to reconsider reinstalling the manifold heat shield, too.
Old Jan 20, 2026 | 06:21 PM
MiniConn's Avatar
MiniConn
2015 Countryman All4 JCW. Picked it up in early November 2025. Car had 108k on it and was in limp mode on way home. Ended up the wastegate actuator was missing a nut so rod was just moving independently of wastegate = no boost. Was still throwing a mismatched boost code so ended up replacing valve cover due to leaky PCV. Fixed that issue. Car still felt slow and turbo was slow to spool. Due to turbo not boosting per previous issue, I figured the cat was clogged. Replaced all this stuff and she rips now!
High energy coil packs and plugs (ECS)
Valve cover and gaskets
NM Engineering intake
NM module
Replaced all boost pipes with silicone units
TurboX diverter valve (recirc)
K04 hybrid turbo
SS Downpipe with sport cat
Aftermarket FMIC
SS oil supply line and new turbo oil drain pipe
Detroit tuned Cryo timing chain kit
Drained and replaced auto trans fluid with Mobil1 Mini spec'd fluid
Oil/filter after seafoam treatment prior to new turbo and timing chain replacement.
The timing chain was so stretched at 108k that the both vanos were throwing codes and I had to reset the adaptations. Runs like a totally different car now!
Attached Thumbnails How many miles on your R60 Countryman-What repairs have you done to it?-img_7415.jpeg   How many miles on your R60 Countryman-What repairs have you done to it?-img_7888.jpeg
Old Feb 11, 2026 | 08:55 AM
supazuk's Avatar
supazuk
2015 Countryman S ALL4.
Bought New 2015 at 5miles, Currently at 207k, never dealer serviced, All DIY
-Oil ever 5k Mobil 1 5w30 and a mini filter
- 2 windshields early
- wife hit second curb at around 50k got wid of run flats best thing I ever did!
-I did my brakes and rotors don't remember what mileage
-70K replaced Alternator
-95k I hit a deer Insurance company cut me a check for 5K for repairs ...... of course i'm doing it my self
so since I had front came off needed a radiator condenser radiator core and hood
Timing Chain - (Detroit Tuned cryo set)
water pump,Idler,Friction Drive, PCV ,turbo oil line, spark plugs, Thermostat, all belts and hoses
Upgraded to AFE cold air intake silicon boast hoses. oh and i put a Bad Boy Air horn in Plus a MEGAN strut tower brace
- took apart head lights to paint inside black added black head and tail light rings removed all emblems
-150k rear struts
-160k all 4 wheel bearings (one went bad did them) all -second set brakes and rotors
-190K exhaust flex pipe went ... did full cat back exhaust just because! - lower right ball joint
- 200K killed the front oil seal replaced it but not long after the oil killed the AC compressor clutch. I went on Car-part.com found a local yard with a used compressor bought it and swapped the clutch and a new belt
-207K things to do:
-needs rotors they are glazed and warped (son was learning to drive unfortunately with 2 feet )
-I have new front struts and the passenger door handle stopped working got a used replacement on Ebay.
-front driver seat is showing a slight crack might just toss covers on
