R50/53 Squeak when turning hard right and now ABS, asc light coming on
Old Dec 29, 2025 | 10:29 AM
john411's Avatar
john411
The lights come on suddenly but then might go away and then not come on for days. In your opinion what could be causing the squeaking when turning the steering wheel all the way to the right?
Old Dec 29, 2025 | 11:01 AM
JABowders's Avatar
JABowders
Veteran: Army
ABS and ASC Lights coming on at the same time normally points to a wheel coder or sensor (ABS Ring and or pick-up sensor) it works like this ...
The pick-up sensor is Item #2 ... but before replacing anything you need to get in there and check the connections and the suspension parts, check to see if anything is loose or out of whack. This can also possibly throw the Tire Pressure warning light as well.
Old Dec 29, 2025 | 11:27 AM
ssoliman's Avatar
ssoliman
what kind off squeaking? might do a video
Old Dec 29, 2025 | 11:46 AM
john411's Avatar
john411
I'll get one as soon as I can.
Old Dec 29, 2025 | 12:34 PM
john411's Avatar
john411
Ok here it is. I had to place phone by the dash so it's blurry but you can hear the noise
https://files.fm/u/3f7smz6ja6
Old Dec 29, 2025 | 12:55 PM
GLTHR53's Avatar
GLTHR53
That sounds more like brakes. Check your pads
Old Dec 29, 2025 | 03:45 PM
john411's Avatar
john411
Thanks. Do you know why it could be making that noise only while turning right?
Old Dec 29, 2025 | 05:41 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Just a wild guess;
You may want to get the front end up in the air - Check that your caliper has not come loose, outer balljoint, or possibly a brake pad has broken loose?
If I'm not mistaken, the wear sensor is on the front left on a Mini. ...at least it is on my 04 R53.
Old Dec 29, 2025 | 06:31 PM
noodlesandsam's Avatar
noodlesandsam
I had an abs sensor go bad - replaced it, went bad again quickly. It was the wheel bearing - it went bad, and was hitting the sensor. These guys are getting old. Stick with good bearings / NSK / ***. I got mine at FCPEuro. Left went to 150k, right to 185k. Secure the car, and tug on the wheel, both up and down and left / right.
Old Dec 29, 2025 | 09:25 PM
john411's Avatar
john411
I had all the wheel bearings replaced less than a year ago but it could be the aftermarket part was cheap of that is the case.
SpiderX
Feb 21, 2019 01:11 PM
Etmil35
R60/R61 Stock Problems/Issues
May 15, 2018 06:27 AM
tedmid
Aug 2, 2017 06:49 AM
Silverbullit
May 23, 2014 03:31 PM
Rossii
Dec 31, 2011 12:07 AM
