R50/53 fault finding/ clutch issue
Hello everyone, my clutch pedal suddenly went soft and the car (2003 cooper manual) would not go into gear. I found the clutch cylinder had broken, replaced it, pressure bled but the still pedal felt the same and now after operating the pedal a lot..the replacement has also broken in the same way.
I can move the arm which operates the fork about 1 inch with my fingers with little resistance.
does it look like a clutch, fork issue or did i just muller the replacement cylinder when fitting it
Im rather attached to the car which is otherwise in good condition.
Thank you for any help or insight you can offer
TonyMastodon
Oct 19, 2015 09:59 AM
sgrever
Oct 20, 2002 06:13 AM
