R56 Thermostat threads cross threading
Old Oct 11, 2025 | 01:58 PM
mini-is-for-me's Avatar
mini-is-for-me
Help!!!
I’m trying to remove my thermostat and one of my screws appears to be crossed threading on exit. Anyone know how to fix that? The first few turns are fine and then it gets tighter and tighter like it is cross threading
Old Oct 11, 2025 | 02:14 PM
Filmy's Avatar
Filmy
The bolts aren't gonna cross thread on the way out - maybe the bolt threads were damaged on install but it shouldn't be too bad if the bolt starts turning freely in the first place; it's probably some crud on the end of the bolt(s). Try loosening them as far as you can, then add some thread corrosion lubricant (like PB Blaster) to the exposed threads, and screw the bolt(s) back in. Do this back and forth as much as you can and the bolt will likely eventually come all the way out.
Old Oct 25, 2025 | 03:31 PM
mini-is-for-me
Thanks.
Yeah, I put the PB blaster on there and unscrewed them and they were just really really tight after 3-4 loose turns...instead of the other way around. Bizarre. They they out without any damage.
redwhiteR562007
Apr 21, 2021 10:23 AM
hooverr77
Aug 23, 2020 09:15 AM
BEAVR
May 31, 2014 09:53 AM
cosmosmpower
Dec 6, 2011 02:12 PM
danmx
Oct 2, 2010 05:32 PM
