R56 Upstream air leak smoke test
Old Sep 11, 2025 | 09:01 AM
Seaswood's Avatar
Seaswood
Error 1497 upstream air leak have a smoke machine where is the best place to attach to air system?
2009 R56 S
craig
Old Sep 11, 2025 | 11:26 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Information at this link may help in terms of possible locations for the leak.
Downstream of the air filter with respect to where to introduce the smoke...
Old Sep 11, 2025 | 12:39 PM
Seaswood's Avatar
Seaswood
So looks like I could put it in the front air intake that goes directly into the air box maybe that would need the filter removed.
possibly after air filter.
Old Sep 11, 2025 | 01:03 PM
Maybe, maybe not
Community Builder
Any air leak upstream of the MAF sensor would not register as an air leak, so your efforts should focus downstream of the sensor.
Old Sep 11, 2025 | 01:12 PM
Seaswood's Avatar
Seaswood
MAF that is where multi plug goes in chamber coming out of the airbox?
Old Sep 11, 2025 | 01:18 PM
Maybe, maybe not
Community Builder
Old Sep 11, 2025 | 01:46 PM
Seaswood's Avatar
Seaswood
Yes thank you.
Old Sep 12, 2025 | 09:02 AM
Seaswood's Avatar
Seaswood
Initial test using a rag to seal the hose as the pipe off MAF is large hard to seal, repacked again was better but no apparent leaks I could see.
Where I thought they would be smoke was exiting around the rag but less second try.
initally used a funnel taped was worse, as advertised this smoke is nasty!
I could try the connector rear of valve cover passenger side smaller opening, do not know how fas the smoke gets?
Old Sep 12, 2025 | 10:14 AM
Maybe, maybe not
Community Builder
Any oil leaks from the valve cover gasket or the PCV diaphragm?
Also note that a faulty MAF sensor can trigger P1497.
Old Sep 12, 2025 | 10:31 AM
Seaswood's Avatar
Seaswood
Valve cover was replaced before I started all the work sealing leaking oil leaks.
i was wondering if it could be a MAP sensor?
i may try another test from connector back of valve cover just to check valve cover then look at MAF.
Thnx
Old Sep 14, 2025 | 02:13 PM
Seaswood's Avatar
Seaswood
The replacement MAF Bosch OEM number is different from original number which is a MINI number, I suppose could be difference?
Old Sep 14, 2025 | 02:32 PM
Maybe, maybe not
Community Builder
Enter last 7 digits of your VIN here. Then search for "Hot-film air mass meter".
Is the Bosch part # a direct replacement for the Real OEM part #?
Old Sep 14, 2025 | 03:01 PM
Seaswood's Avatar
Seaswood
I looked but there is no category air system what would air system be listed under?
Old Sep 14, 2025 | 03:22 PM
Maybe, maybe not
Community Builder
Enter the sensor name here:
OR
Locate sensor here:
Old Sep 14, 2025 | 03:30 PM
Seaswood's Avatar
Seaswood
I had checked but did not check fuel now I know thank you yes a match!
Old Sep 14, 2025 | 03:31 PM
Maybe, maybe not
Community Builder
You're good to go. Good luck!
Old Sep 15, 2025 | 08:02 AM
Seaswood's Avatar
Seaswood
This part is on a long list of parts I recently replaced fixed resealed starting with the oil filter housing need to lift car after this is installed to verify the seals.
but no oil on the floor is good sign.
and car just before this passed 100,000 miles
Old Sep 15, 2025 | 09:53 AM
Maybe, maybe not
Community Builder
Old Sep 30, 2025 | 11:00 AM
Seaswood's Avatar
Seaswood
Unfortunately P1497 error came back so maybe I need to use a smaller hose to insert the smoke get a more positive seal.
And PO13E O2 sensors, originally I bought new sensors not mini was told needed Mini O2 sensors that I got & installed.
i looked these are specific to location & wiring so cannot be fitted improperly? They were bought from Mini $$$ why would new O2 sensors fail?
Old Sep 30, 2025 | 03:23 PM
Maybe, maybe not
Community Builder
You get much more diagnostic information by retrieving BMW fault codes. And an O2 sensor fault code does not necessarily mean a bad O2 sensor (e.g., issue could be a bad wire, DME, etc.).
Have a look at this AI-generated information. The code indicates a fault related to the downstream sensor.
Old Sep 30, 2025 | 04:21 PM
Seaswood's Avatar
Seaswood
Okay so in doing all the work I did the Cat removal to access the oil filter housing oil cooler so on so Cat connections the lower has that clamp the flex hose?
the wiring I had quite a bit of time to look at but still could revisit that. Car runs okay mostly for 100,000 miles, still having everything apart for some time there are lots of places in question. Thanks for your input never is as simple as it would appear?
Old Mar 29, 2026 | 10:09 AM
Seaswood's Avatar
Seaswood
Flex pipe
Continuing to look for downstream air leak P1497 & P013E, O2 sensor with my generic code reader.
smoke tests do not reveal much?
wondering about the flex pipe connecting to Cat & exhaust pipe as front end has a clamp the rear end does not, rear connector is loose?
Nor is there one listed in the fiche, but Ecs has a second clamp listed.
should I assume the flex pipe rear connector uses a pipe connector, is a flat clamp versus the one with a ridge?
otherwise I need to go to a shop have codes read!
Old Mar 29, 2026 | 08:48 PM
Maybe, maybe not
Community Builder
Just an FYI - P013E is most likely caused by the unmetered intake air leak (P1497).
Old Mar 30, 2026 | 02:55 AM
Seaswood's Avatar
Seaswood
Thnx yes that is likely the codes come up after 15-16 miles.
just wondering if a missing clamp on flex hose rear to exhaust could cause those symptoms?
Old Mar 30, 2026 | 04:19 PM
Maybe, maybe not
Community Builder
It's possible.
Seaswood
May 10, 2025 04:58 AM
kyoo
Jun 19, 2018 02:41 PM
Ixx
Mar 20, 2012 09:07 AM
Dwight Walhood
Mar 16, 2010 09:20 AM
