R55 What work would you do IN CONJUNCTION with engine replacement?
Old Aug 21, 2025 | 01:46 PM
howlinmad's Avatar
howlinmad
Hello,
I have a 2008 R55 Clubman S that is getting a newer engine. While the front is off, and engine is out, what addition work would you do to take advantage of easy access to engine and engine bay?
I plan to replace engine and trans mount, water pump and timing, and PCV.
anything else you recommend?
thank you,
Old Aug 21, 2025 | 04:22 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
If any A/C system work is required, then do it when the engine is out.
Old Aug 26, 2025 | 05:04 PM
spaktacular's Avatar
spaktacular
Originally Posted by howlinmad
Hello,
thank you,
Not sure if you're pulling the subframe out, but if so it's a great time to address all the associated bushings.
Only other bits that are easily accessed with the engine out are the heating hoses.
Old Aug 27, 2025 | 05:32 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yup, I would do a subframe refresh with new poly control arm bushings and poly sway bar bushings. Also give consideration to clutch replacement. Parts are cheap once the engine is out. Manual transmission? Maybe add an LSD swap, too. How far do you want to go?
Old Aug 27, 2025 | 12:12 PM
howlinmad's Avatar
howlinmad
The bushings seem like an excellent idea - thanks to all. And I can afford that. After all the ones in there are 17 years old and over 120k miles.
it is Automatic Transmission.
Old Aug 27, 2025 | 01:10 PM
spaktacular
I recommend the PSB bushings for the control arms. They have a much lower cost than the Powerflex product, and I can say the installation is relatively easy. You will need to have some sort of bushing install tool/press to install ANY bushing in to your existing housing; if you don't have this capability, then I'd recommend buying something like this>
https://www.rockauto.com/en/moreinfo...%2FS7MOg%3D%3D
Old Oct 16, 2025 | 09:11 AM
howlinmad's Avatar
howlinmad
Well - the rebuild has started.
all seems to be going well. Fresh belts, chains, gaskets, etc going onto the “new engine”.
now I have a shell of a R56, sans engine and trans
any ideas as to selling?
thank you in advance and thank you for the rebuilding advice.
martin
yonatan11
Jan 5, 2012 11:13 AM
mini_r53
Mar 19, 2007 08:13 PM
turbo740
Jul 29, 2005 01:39 AM
cafemoc
Detailing 101
20
May 25, 2005 01:10 PM
