R52 R52 S Convertible Top Issue
Old Aug 18, 2025 | 04:45 PM
cnusbtkg's Avatar
cnusbtkg
Ok... so I have dug through all the threads here and many other places and I seem to have an issue that doesn't fall into any of the typical areas. Please help!
When putting the top down it goes into sunroof mode easily and without issue. When pushing the top down button again, the windows do their thing as expected, the latches release as the top slides back, then everything stops and I get the flashing red light. I can close everything by using the close button. The parcel shelf switches seem to be ok, since the top unlatches, etc.before I get the red flashing light. Has anyone experienced the same this / what issue does this sound like to everyone? Does this sound like a hall sensor issue?
Much appreciated as always - Motor On!
Old Aug 19, 2025 | 11:31 AM
Fly'n Brick's Avatar
Fly'n Brick
There's also a push button on the upper left corner in the boot door frame. It has a short throw. I stuck a small felt chair leg pad on the boot door opposite and have never had a problem.
Old Aug 21, 2025 | 11:37 AM
cnusbtkg's Avatar
cnusbtkg
Thanks for the thought. All the rear switches / microswitches are engaged as the sliding portion of the top makes it 3-4" move back as the latches unlock. Then everything stops and I get the flashing light. Just borrowed a Snap-On scanner - got a Control Unit Not Coded and a Coding Data Incorrect. Sounds like I need to dig out the control module. Thoughts anyone?
Old Feb 6, 2026 | 10:16 AM
Ollie777's Avatar
Ollie777
Mini roof issues
Please all remember the electro hydraulic motor so it has parts in it that go wrong eg motor brushes and fluid and so on.
Old Feb 6, 2026 | 12:00 PM
Here is all the other info.
https://www.northamericanmotoring.co...t-opening.html
Yep the lines can leak and if the fluid reservoir leaks you have to replace the bump.
https://www.northamericanmotoring.co...ump-valve.html
On a R57 but similair
Pump https://www.ecstuning.com/Search/Sit...h/54347019872/
Soft top motor used - Mini MINI - 54347019872 - GPA
You can get items on their own: https://www.realoem.com/bmw/enUS/sho...diagId=54_0345
Mamabird
Aug 10, 2023 09:17 AM
MasterOfNothing
Sep 4, 2021 02:43 PM
Zachary Pollard
R57 :: Cabrio Talk (2009+)
Mar 21, 2021 08:16 PM
ranczar
Nov 23, 2010 10:28 PM
Masakik
Oct 15, 2010 07:58 AM
